Laminate Countertops Warped - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-29-2015, 12:05 PM   #1
Love projects
Bigbluefrog's Avatar
Rewards Points: 174
Laminate countertops warped
Just bought new laminate countertops and noticed a slight warp concave along the width of all of them. Haven't installed them. Will installation correct it? Or should I sand 45 degree angle to make fit.
Bigbluefrog is offline   Reply With Quote
Old 03-29-2015, 01:17 PM   #2
Property Mgt/Maint
Rewards Points: 6,368
Not sure if I understand the problem. Are your ends lifted due to full length cupping on your longest piece? If so how much is each end lifted? And are you using a seam kit that bolts your edges together tightly?
[political signature removed]
Yodaman is offline   Reply With Quote
Old 03-29-2015, 01:59 PM   #3
Love projects
Rewards Points: 174
Seam kit..yes. less than a 1/4 inch on each end.
Old 03-29-2015, 02:03 PM   #4
Love projects
Rewards Points: 174
Concave dips in middle between wall and face of cabinets. The whole length of countertop. Well water wont spill off of it. Have fasterners for the end I cut and fasterners kit for precut groove on exsisting 45 degree angle.
Old 03-29-2015, 03:23 PM   #5
Property Mgt/Maint
If you have a concave dip from front to back, my biggest concern is getting a nice flat seam where both edges come together. If that is not possible then prospects are dimming. The ends should be attached first and then the entire top gets attached to the cabinets. Unfortunately the the flimsy little mounting brackets on the top of cabinets will do little to straighten out a front to back dip. But if you can get the seams together time and gravity will be your friend.
The Following User Says Thank You to Yodaman For This Useful Post:
Bigbluefrog (03-29-2015)
Old 03-29-2015, 03:24 PM   #6
Love projects
Rewards Points: 174
I sanded edge to fit bettern..and used wood shims to level. I think it will work after it is tightenedn.
Old 03-29-2015, 07:11 PM   #7
Love projects
Rewards Points: 174
Yodaman that is exactly the issue I had...getting the seams to be flush. Did the best I could. I was thinking the first time we ever had seams. A U-shaped kitchen verses the galley kitchen. It was a close fit. Not perfect...if the large piece wasnt warped it would of been better.
Old 03-30-2015, 08:26 AM   #8
Property Mgt/Maint
Good job, maybe if you ever do another similar top, consider building from scratch and doing your own laminate work. Not as difficult as one might think.
Old 04-03-2015, 11:48 PM   #9
Love projects
Rewards Points: 174
Yodaman, have you done that? the rotary tool, I left my router at home for trimming excessive endcaps. So I am not quite done. Tried using a different tool and I have a slight chip on one. That one will be flush against oven. My other half has an idea to fix with matching color and light tip coat
Old 04-04-2015, 07:00 AM   #10
Property Mgt/Maint
Yes I have. Always used a router with base attached to do edges. A flat file will work in a pinch if your edges are cut close. My hand is not steady enough to try a rotary tool.
Old 04-04-2015, 08:05 AM   #11
Love projects
Rewards Points: 174
That is why it chipped. I have 4 more caps to trim. This time with the Right tool
Installing Laminate Countertops tsherv Remodeling 5 04-24-2013 09:45 AM
Laminate Countertops cibula11 General DIY Discussions 6 08-31-2011 04:05 PM
Need advice/tips on tearing out old laminate countertops TumsGum Kitchen & Bath Remodeling 6 03-07-2009 09:52 AM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
Wilsonart post-form laminate countertops?? J187 Remodeling 7 05-04-2007 02:16 PM
