Kitchen Flooring Advice - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-05-2014, 08:14 AM   #1
Rewards Points: 49
kitchen flooring advice
hi... I was wondering if I could put linoleum flooring over existing vinyl tile, or do I have to remove it all first. Because when I took off a few tiles, the glue was difficult to remove from OSB and peeled plywood pieces off.
Would you see where I took off tiles through the linoleum? there's not that much difference as the existing vinyl is very thin. Just wanted to ask first, thank you for your time...
jambud is offline   Reply With Quote
Old 11-06-2014, 05:42 AM   #2
Retired Moderator
Rewards Points: 7,174
Yes, sheet goods can be laid over the top of clean ,flat vinyl tiles---you will need to patch any cracks/missing tiles---flat and smooth is the key word.
Ardex 'Feather Finish' may be the patching compound for this job.
Kitchen floor advice in old house wingedmare3 Flooring 7 03-09-2014 04:03 PM
Advice on Flooring Options mjkpainting Flooring 4 06-05-2013 07:14 AM
Advice on inexpensive flooring?? sheiladderr Flooring 5 01-20-2012 02:37 PM
kitchen flooring options christineka Flooring 4 03-10-2011 02:52 PM
Engineered Flooring in Kitchen Hages Flooring 1 03-29-2007 01:30 PM
