Kitchen Backsplash Material - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-30-2015, 06:37 PM   #1
Rewards Points: 28
kitchen backsplash material
My wife ordered stacked stone (looks like irregular flagstone material) for a kitchen backsplash. Apparently the flooring and tile place told her that it was the latest "thing", and perfectly acceptable and we both love the look. I was hesitant when I saw it. It was installed today and I don't think it was a good recommendation.
It is irregular in depth, has tons of joints and crevices to catch food and liquids, and electric outlets and switches are impossible to mount securely. Liquid could splash behind an outlet since there is no seal there as they are impossible to seal tight properly.
A remodeler who installed the sink said he can't believe someone sold us this stuff for a backsplash. In his experience, most people end up taking it out. Anyone with experience here? Thanks for your help!
ETex2 is offline   Reply With Quote
Old 09-30-2015, 06:49 PM   #2
Retired Moderator
Rewards Points: 7,174
Oh,boy.
If it is going to be a huge disappointment--you know what you need to do.
Some times things look better in the show room.
rjniles (09-30-2015)
Old 09-30-2015, 07:50 PM   #3
ZZZZZ's Avatar
Rewards Points: 2,172
There is a reason they call it a "backsplash." Stacked stone isn't exactly easily washed and cleaned.
Stacked stone may look good to a designer, but "in" usually means expensive and impractical.
ZZZZZ is offline   Reply With Quote
Old 09-30-2015, 08:00 PM   #4
Rewards Points: 5,348
Remove it and pick something better suited to the location.
Ron
B. Franklin 1759
Old 09-30-2015, 08:04 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 748
Oh boy is right.
Hard to believe someone recommended that stuff for a kitchen backsplash.
Maybe they thought you were gonna use a power-washer to clean up.
Remove it soon, the sooner the better,(easier).
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
The Following User Says Thank You to JazMan For This Useful Post:
oh'mike (10-03-2015)
Old 10-04-2015, 12:40 AM   #6
Rewards Points: 2,472
Electricals are not "sealed", unless it is gasket sealed covers. You are not supposed to throw water at it. They are supposed to be certain distance away from the sink. Use GFI outlets.
If you still like the look, accept it. I'd try to find what is good about it, than thinking it can't be kept antiseptic. I rarely cleaned the backsplash. It was cheap marble with grout joints. Germs are on these surfaces as well.
New material, so find another way to clean it. Those steam cleaners may do a good job. Or spray the cleaner, use scrub brush and vacuum off.
carpdad is offline   Reply With Quote
Old 10-04-2015, 10:32 AM   #7
Rewards Points: 4,212
Would I be a hypocrite if I agree with both Oh'mike and carpdad.?
ron45 is offline   Reply With Quote
Old 10-04-2015, 09:38 PM   #8
Rewards Points: 105
It is a popular look right now. When I'm with a customer I try to discuss with them the practicality of these for their backslashes. Had a customer choose it for behind a pellet stove today. A better location than as a backsplash, but it will probably be a great dust collector.
MaineLL is offline   Reply With Quote
Kitchen REMODEL DONE except 4 backsplash lionscourt Interior Decorating 10 11-25-2015 01:50 PM
kitchen backsplash - is this overkill? sylvanthread Interior Decorating 6 01-29-2015 12:11 PM
Material for kitchen cabinets bottoms Gabriel8642 Carpentry 4 08-28-2013 09:13 PM
Installing natural stone kitchen backsplash kathybc Flooring 2 01-22-2012 06:36 PM
Kitchen backsplash over knockdown texture? Ponderous Remodeling 2 01-17-2010 04:14 PM
