Insulation In Basement - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-03-2015, 06:20 PM   #1
Rewards Points: 16
Insulation in basement
I am finishing my basement, and I have a question on insulation. Our choice of flooring is a acid stained concrete.
Am I incorrect in thinking that the insulation in the walls is basically pointless if you have the entire floor bare concrete? We are on a tight budget, and it is a starter home so we don't want to put a ton of money into it.
carter72 is offline   Reply With Quote
Old 08-03-2015, 09:04 PM   #2
Registered User
Rewards Points: 526
Wall insulation is usually a good idea...depends on location; http://www.google.com/url?sa=t&rct=j...7c2C4A&cad=rja
Gary
Old 08-03-2015, 09:24 PM   #3
Rewards Points: 16
I live in an area that shows r5-r9. Also, won't the concrete floor defeat the temperature element?
Old 08-03-2015, 09:59 PM   #4
Rewards Points: 16
Edit: the pdf that first opened isn't the one you posted
I don't live in the north, a different chart suggested r5-9 for where I live. My thought was more about the heat loss from the floor.there is much more surface area from the floor that the small part of the basement I am remodeling
Old 08-04-2015, 06:35 PM   #5
Registered User
Rewards Points: 526
Where do you live?
Gary
PS; http://www.quadlock.com/technical_li...Insulation.pdf
http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja
http://www.google.com/url?sa=t&rct=j...hj_I6fU2ymaUSA
The building looses heat at the perimeter because 6' down the earth warms to soil about 10*F warmer than surface temps.
The Following User Says Thank You to Gary in WA For This Useful Post:
mae-ling (08-04-2015)
Old 08-04-2015, 08:10 PM   #6
Rewards Points: 16
Arkansas
Old 08-04-2015, 08:52 PM   #7
Rewards Points: 2,262
May homes insulate the walls and not the floor.
As Gary said the walls are colder then the floor as the floor is further below ground, some of the basement wall is even above ground.
Moisture (Condensation) is also a concern.
WE use 1.5 or 2" xps glued to the concrete wall, tape the seams, then a 2x4 wall with R12 insulation. Do not poly the inside. Treated bottom plate on the wall of course.
For you if your walls are straight and flat you can use 1.5" xps. (R7) 2" would give you R10 - then use 1x3 (1x6 ripped in 1/2) strapping on top of it attached to wall with concrete screws. Then drywall on that.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
Gary in WA (08-05-2015)
Old 08-07-2015, 06:58 AM   #8
Rewards Points: 2,452
Not exact but I remember this. R value can be adjusted for how much the earth covers and what is exposed. You may save some there. Floor is not a factor. It is deepest part and well insulated by earth.
carpdad is offline   Reply With Quote
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 04:42 PM
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 05:44 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
basement insulation advise needed bmartin5150 Building & Construction 1 04-27-2009 04:56 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
