Installing Beam In 2-story Interior Load-bearing Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-13-2015, 02:44 PM   #1
Rewards Points: 2
installing beam in 2-story interior load-bearing wall
I have a 2-story, interior wall that separates a foyer from a Great Room. I want to remove/open up that wall, but only the lower "half", not all the way up to the ceiling. I have found numerous videos and instructions for replacing load bearing walls with supporting beams, most are fairly simple depending on the application. However, in this type of situation: How do I build a temporary support wall? I can't easily support all the way to the ceiling? if I "scab" supports just above the proposed beam, even if that will be sufficient temporary support (?) that will restrict my access to get the new beam in. Ideas? Solutions?
dgorman is offline   Reply With Quote
Beam for load bearing wall Cattman Building & Construction 1 04-02-2014 11:32 AM
Uncovered a structural question in load bearing wall Pardner Building & Construction 6 01-17-2014 02:32 PM
Updating Timber & Balloon Framed Home (LONG POST) Pittsville Building & Construction 13 05-29-2013 12:15 PM
Beam for Load Bearing Wall jstein69 Building & Construction 3 02-17-2012 05:26 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
