Install Brick Veneer On Existing Ceramic Tiles - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By joecaption
Old 07-19-2018, 08:46 AM   #1
Rewards Points: 4
Install Brick Veneer on existing ceramic tiles
Hi!
I would get a proper advice on installing brick veneer on existing ceramic tiles.
My current kitchen back splash is a white glazed ceramic tile. It will be very expensive to hack down these tiles. I love the farmhouse theme and have always wanted to have a brick back splash.
I thought of pasting wall papers with brick patterns but it will not be a good idea. So now i am thinking of installing thin brick veneers on my existing glazed ceramic tiles. I have been reading so many advises on installing brick veneers. I have even read about applying epoxy primers on the surfaces of the ceramic tiles.
Can anyone guide me accordingly on how do i have to go about installing brick veneer on my existing ceramic tiles? I am really confused.
What do i need to do? Can i overlay the brick veneer directly on top of my existing tiles using mortar or brick adhesive?
Install Brick Veneer on existing ceramic tiles-14324524_976412539136474_2319501303832792635_o.jpg
Daisy.k is offline   Reply With Quote
Old 07-19-2018, 09:00 AM   #2
Guapo
Rewards Points: 11,950
Re: Install Brick Veneer on existing ceramic tiles
You may need to attach wire lath to the wall first.
Guap0_ is offline   Reply With Quote
Old 07-19-2018, 09:20 AM   #3
Rewards Points: 17,890
Wait until you try and clean a brick veneer, not going to happen.
Nealtw likes this.
Old 07-19-2018, 09:41 AM   #4
Rewards Points: 4
How about priming the surface?
Old 07-19-2018, 09:48 AM   #5
Rewards Points: 2,858
You can use this product STO DISPERSION ADHESIVE.
Read the data sheet it states that it can be used as a bonding agent if thinned 10% with water. Than you can use it on the back of the Veneer Brick to adhere the brick to the tile. I have used this over glazed brick , Glass & metal works great.
ClarenceBauer is online now   Reply With Quote
Help me install new tiles M4rtin Tiling, ceramics, marble 22 02-04-2016 05:27 AM
Pros please help - what method attach porch roof to brick veneer dinoburger Concrete, Stone & Masonry 6 08-02-2015 10:57 AM
Replacing 2 ceramic tiles over Ditra RichardZ Flooring 33 01-17-2013 12:22 PM
Enlarge an existing hole in ceramic tiles miamicuse Tiling, ceramics, marble 4 08-25-2012 10:50 PM
Brick veneer is 4 rows below grade- redo or leave? cbrc5eric Building & Construction 11 12-27-2011 08:09 PM
