Impossible? Staircase Remodel - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-22-2016, 09:24 PM
Rewards Points: 22
Re: Impossible? staircase remodel
Originally Posted by BigJim View Post
Look at the second picture, there looks to be a screw in the side of the stringer, I would guess that is holding the treads in place. You might want to try that.
I did. It holds the bracket in place.
jilly55 is offline
Old 03-22-2016, 09:29 PM
Rewards Points: 22
Originally Posted by Fix'n it View Post
that is what i was going to say, and why i asked for those pics. that 1 screw and perhaps(perhaps not) the top bolt of the rail. those things come out of there, no doubt.
no bolt on the rail. they don't come out. I wish I could have you all over for coffee or beer and show you my dilemna. oh well...
jilly55 is offline
Old 03-22-2016, 09:39 PM
Rewards Points: 996
yes they do, 99.9% anyway. post a closeup of the fastener at the arrow.
Fix'n it is offline
Old 03-23-2016, 09:58 AM
Rewards Points: 22
my bad, there are bolts for the rails. How would removing the rail help?
Impossible?  staircase remodel-1458744790220-1196984569.jpg   Impossible?  staircase remodel-1458744905539902164889.jpg
jilly55 is offline
Old 03-23-2016, 10:08 AM
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,486
We were referring to the screw infront of the spindle, not the one in the spindle. Does it not screw into the tread? If that isn't it, something else is holding the treads in place.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now
Old 03-23-2016, 08:21 PM
Rewards Points: 996
the one i pointed at. it looks like it has a TORX head. but hard to tell, pic isn't close or clear enough.
Fix'n it is offline
Old 03-23-2016, 08:33 PM
Rewards Points: 7,190
rather looks like the treads are positioned like this
SPS-1 is offline
Old 03-26-2016, 09:07 PM
Rewards Points: 22
Treads are positioned as you show. That screw is holding the bracket that the tread sits in.
The treads are held in place by the stringers(?) I explained the process a few messages back. Many thanks for all the help. It cannot be done without disassembling and I am not up for that.
jilly55 is offline
Staircase and stair area renovations chukker Remodeling 25 07-12-2014 08:05 AM
staircase remodel: removing riser jsunsun Carpentry 14 12-12-2012 09:39 PM
fix sag around staircase fixhouse Building & Construction 3 02-09-2012 06:16 PM
Space needed for L-shaped staircase with 2 landings redpanda Building & Construction 1 07-28-2010 06:32 PM
Staircase help please!!! sdba Carpentry 3 02-09-2010 12:58 PM
