Impossible? Staircase Remodel - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-16-2016, 02:03 PM   #1
Rewards Points: 22
Unhappy
Impossible? staircase remodel
Hi all. I am new to this and joined as I am trying to teach myself some carpentry. I am a remarried newlywed(almost 3 yrs) and moved into my husband's home. It has MANY beautiful attributes, but one improvement I would love to do is the staircase. It was custommade in the "industrial" style. The metal staircase was put together around the wood treads. If I can talk him into allowing me to cut through the treads, would there be any way to install new treads into this non-flexible staircase?? This is all so I can paint the metal. It is currently primer yellow ANY suggestions would be welcome. I am willing to try anything. He will not take kindly to me disassembling them, however
Thanks to any responses, in advance.
Impossible?  staircase remodel-1458154910274-585925150.jpg   Impossible?  staircase remodel-1458154992595-403497179.jpg
jilly55 is offline   Reply With Quote
Old 03-16-2016, 03:27 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,510
Re: Impossible? staircase remodel
Take one tread loose, slide it back away from where it is mounted, push one end of the tread up as high as it will go and pull the other end down. See if there is enough room to clear that bottom flange. If not, all is left is to remove one side of the metal stringer.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
jilly55 (03-19-2016)
Old 03-16-2016, 06:57 PM   #3
Rewards Points: 7,228
Looks like I see L brackets welded to the stringers to hold the stair treads. Possibly two or three screws on the underside into the wooden tread? Even if you cant get the treads out, you could loosen perhaps 5 or 6 of the treads, and slide them up or down the stairway. Then you would have perhaps a third of the stairway clear to paint ----- repeat 3 times.
SPS-1 is online now   Reply With Quote
The Following User Says Thank You to SPS-1 For This Useful Post:
Old 03-17-2016, 11:52 AM   #4
Rewards Points: 459
Originally Posted by jilly55 View Post
...This is all so I can paint the metal...
Sounds like a lot more work than just masking off the treads. Why do you feel like you need to remove them?
Nick DIY is offline   Reply With Quote
The Following 3 Users Say Thank You to Nick DIY For This Useful Post:
Bondo (03-19-2016), dd57chevy (03-17-2016), jilly55 (03-19-2016)
Old 03-19-2016, 08:10 AM   #5
Rewards Points: 22
I have tried that route. Removing the stringer on one side is not an option, unfortunately. Many thanks for the reply.
Old 03-19-2016, 08:15 AM   #6
Rewards Points: 6,905
Would you take the engine out of a car to change the oil?
Rethink your approach to this and I bet you can find a way to paint the metal with the treads in place.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is online now   Reply With Quote
Old 03-19-2016, 08:21 AM   #7
Rewards Points: 22
Originally Posted by SPS-1 View Post
Looks like I see L brackets welded to the stringers to hold the stair treads. Possibly two or three screws on the underside into the wooden tread?.
There are no screws on the underside. I was hoping the same. I took one L bracket off to try that option. I still cannot get the tread out and I can loosen it, but only an inch or so. It still didn't really help.
Old 03-19-2016, 08:26 AM   #8
Rewards Points: 22
Since I am painting a new color, the only way to paint all of it is to remove the tread. The inside, underside, L brackets are all yellow. I doubt I can cover all by taping off. I guess I will find out, as it is my only option.
Old 03-19-2016, 08:32 AM   #9
Rewards Points: 22
No, I would not, but that is not an apples to apples comparison. I would take the engine out to repaint it.
I know my only option is to tape them off. I was hoping I had not thought of a fairly simple solution.
Thanks for the input.
Old 03-20-2016, 09:44 AM   #10
Rewards Points: 996
post pics of the outside of the stringer and underneath where the treads are attached.
taping and painting that in place would be a real pita.
Fix'n it is offline   Reply With Quote
Old 03-20-2016, 10:26 AM   #11
Rewards Points: 106
when you say install new treads, what where you thinking of installing to replace the existing ones? I daught the wood was installed then the stairs welded together, they should be able tobe removed..
goobertime is offline   Reply With Quote
Old 03-21-2016, 10:36 AM   #12
Rewards Points: 22
Here are pics. Have decided to just do the best I can taping. Removing treads is not an option.
Impossible?  staircase remodel-1458574237971-1800030960.jpg   Impossible?  staircase remodel-1458574348450-1803539065.jpg   Impossible?  staircase remodel-1458574405539-1368371670.jpg
Old 03-21-2016, 10:42 AM   #13
Rewards Points: 22
Actually, that is exactly how they were assembled. Not welded, but stringers were attached around wooden treads. One side went up, treads were put in place and the the other side put up tightly against treads to keep them in place. Apparently, it took four adults to do it. I was thinking wood again for treads, but oh well. I need to pick my battles and I have decided this is not one of them.
Old 03-21-2016, 10:47 AM   #14
Ole Wood Worker
BigJim's Avatar
Look at the second picture, there looks to be a screw in the side of the stringer, I would guess that is holding the treads in place. You might want to try that.
Jim
Old 03-21-2016, 07:49 PM   #15
Rewards Points: 996
that is what i was going to say, and why i asked for those pics. that 1 screw and perhaps(perhaps not) the top bolt of the rail. those things come out of there, no doubt.
Staircase and stair area renovations chukker Remodeling 25 07-12-2014 08:05 AM
staircase remodel: removing riser jsunsun Carpentry 14 12-12-2012 09:39 PM
fix sag around staircase fixhouse Building & Construction 3 02-09-2012 06:16 PM
Space needed for L-shaped staircase with 2 landings redpanda Building & Construction 1 07-28-2010 06:32 PM
Staircase help please!!! sdba Carpentry 3 02-09-2010 12:58 PM
