Identifying Load Bearing Posts - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-07-2016, 07:11 AM   #1
Rewards Points: 8
We took down a pony wall to the load bearing posts (3 2x4's nailed together). We are now taking down an L shaped wall about 15 feet from the load bearing post. There is a load bearing post (3 2x4's nailed together). About 3 feet from that post was a pocket door frame. When I took down the door frame I found 2 2x4's nailed together with another 2x4 that was part of the door frame but not attached to the 2 2x4's. Could this be a load bearing post? How do I know. I do not think it is but my husband thinks it might be. Can anyone help?
Reader1 is offline   Reply With Quote
Old 06-07-2016, 10:22 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Identifying Load Bearing Posts
Might need a picture.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 06-08-2016, 09:17 PM   #3
Rewards Points: 8
Thanks. I will try to get a picture tomorrow.
Old 06-10-2016, 08:47 AM   #4
Rewards Points: 2,458
Min I'd want to see how the floor and ceiling/roof are tied to that post. This is not easy on a photo, though some are obvious. Either trust your instinct (everybody is somewhat aware of gravity) or look for an old carpenter.
carpdad is offline   Reply With Quote
Help...are the 4x4 posts load bearing?? Ponderous Building & Construction 7 04-10-2016 10:10 AM
meter/main combo to load center grounds and bonding? ronsquery Electrical 2 03-16-2013 05:29 AM
Is This a Load Bearing Wall? Want to remove it. wowor Building & Construction 5 02-14-2013 04:17 PM
Load Bearing wall or not? Dennis6950 Remodeling 5 02-01-2011 08:34 PM
Removing a load bearing wall, adding a beam ? Lakedriven Building & Construction 9 11-02-2010 07:12 AM
