Ideas For A Temp Basement Solution - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By ChuckF.
  • 1 Post By stick\shift
Old 01-20-2018, 04:43 PM   #1
Rewards Points: 432
Ideas for a temp basement solution
I have this basement and want to put something over the insulation / studs in the walls and ceiling, cheap and fast. Don't care about it being "finished" more just don't want to look at the insulation. Also don't need to cover the cement bottom of the wall. Room will be an art studio.
Was thinking about putting Tyvek (white side to room) over it all. The home inspector said NO, as it would trap moisture. He recommended drywall. I mentioned that Tyvek has the ability to breath, but he said not enough and that drywall can breath. (It's hard for me to believe that drywall would breath much at all after it's taped and painted..but what do I know?)
Another thought is to build out on the studs with a 2 x 2 or 2 x 4 and then put up some sheet metal panels. That would also leave a gap behind for the air to flow. As I'm typing this it occurs to me that I could build out the studs and put tyvek on that, again leaving some room for air to breath.
I want it cheap and also something that doesn't degass, formaldehyde, glues, etc are not my friend.
TIA!
UltraRed
UltraRed is offline   Reply With Quote
Old 01-20-2018, 08:15 PM   #2
Rewards Points: 972
Re: Ideas for a temp basement solution
Drywall.
NotYerUncleBob2 is offline   Reply With Quote
Old 01-20-2018, 08:45 PM   #3
Guapo
Rewards Points: 11,950
Better yet, paneling.
Guap0_ is offline   Reply With Quote
Old 01-21-2018, 12:46 AM   #4
jlhaslip's Avatar
Rewards Points: 708
Oriented Strand Board (OSB) is another option.
Where are you located? In a cold climate, you would also need a vapour barrier underneath the wall material.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 01-21-2018, 03:18 AM   #5
JUSTA MEMBER
Rewards Points: 3,574
Drywall, you do not have to tape, mud, and or finish paint it.
Just hang it and leave it.
ED
de-nagorg is online now   Reply With Quote
Old 01-21-2018, 10:29 PM   #6
Rewards Points: 1,744
Agree on the drywall. I understand the desire to sometimes do something quick and dirty, but you will find temporary turns into years, and you realize that for 20% more work you could have done something much nicer that you will take pride in.
Drywall, don't do the joints. Use screws; space the screws in the same place on each sheet so it looks nice. See about that vapor barrier question.
de-nagorg likes this.
ChuckF. is online now   Reply With Quote
Old 01-22-2018, 03:00 PM   #7
Rewards Points: 4,094
Drywall.
stick\shift is offline   Reply With Quote
Old 02-08-2018, 03:07 AM   #8
Rewards Points: 16
I agree with drywall, actually look in to the future as how this space could be used, looks like a horse barn now but could be an entertainment area. Look at how much the area could be used for resale value if it is a usable space.
kritterkare is offline   Reply With Quote
Basement Decoration ideas tescatlipoca Interior Decorating 5 06-19-2015 01:07 AM
basement ceilings Ideas Needed Kmikrot Remodeling 7 10-01-2012 09:45 AM
best door solution for basement under ductwork joem01 Building & Construction 10 01-18-2012 01:15 PM
Basement Fireplace Ideas DAdams982 Remodeling 6 01-28-2011 12:35 PM
Need HVAC solution for basement - 3 zone? or ductless units? skylake HVAC 2 10-06-2009 07:42 PM
