How To Square Off Top Of This Arched Passageway - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Tymbo
Old 08-11-2018, 09:45 AM   #1
Rewards Points: 110
How to square off top of this arched passageway
Would like to square off this arched passage way.
If i remove the the top corners of drywall will I find two 45 degree studs framing the arch, and could I remove them and form the two sides as 90 degree corners?
Anyone out there ever tackled this arch modification?
Thanks for your help
provlima is offline   Reply With Quote
Old 08-11-2018, 09:52 AM   #2
retired framer
Rewards Points: 18,610
Re: How to square off top of this arched passageway
Yes you can remove that crap, it will just be a 2x4.
Nealtw is offline   Reply With Quote
Old 08-11-2018, 09:57 AM   #3
Rewards Points: 334
I think you have it figured correctly.
If I were doing this, I would square off the framing as you suggest, but I would add a jamb and casing to make a cased opening. Then you won't have to mess with replacing corner beading and mudding.
Plus it will look much nicer!
Nealtw likes this.
Tymbo is offline   Reply With Quote
Old 08-11-2018, 03:50 PM   #4
Rewards Points: 6,889
More than likely, yes and yes; only the one I tore out was a terrible arc.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 08-11-2018, 05:21 PM   #5
Rewards Points: 1,406
Yep, the arches can be bad, as they can be built from short blocks or plywood /OSB cut in an arch form to tear out.
I suspect as the others here do though, the OP will be finding something like this.....
Gregsoldtruck79 is offline   Reply With Quote
How to best tell what is square and what is not? miamicuse Building & Construction 12 07-14-2012 08:44 PM
1CFM per square foot, or follow heat load calculation? JeepNick HVAC 10 02-08-2012 04:10 PM
Return Air in a 100 square foot closet? JeepNick HVAC 13 02-07-2012 10:21 PM
Getting a 200Amp Square D OQ Panel. What about surge protector? mudworm Electrical 3 10-27-2011 02:29 PM
Placing trusses on a severely out of square building way2fastxl1200c Building & Construction 6 04-20-2010 10:09 PM
