How Should I Resize My Doors? - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-28-2014, 03:02 PM   #1
Unhappy
How should I resize my doors?
Hello,
I recently remodeled my master bedroom and deleted a couple of doors and added a pair of closets with 4' openings. The plan was to put in bi-fold doors but the cost is insane at $70 each 2' door. Thats $280 for both closets.
I have four solid wood two panel doors that measure between 28"-32" each. How should I go about cutting them down is my question? Should I rip a section out the middle and splice them together? If so, I don't have a biscuit jointer, can I create a mortis and put a wooden tenon in? Should the cut be off center? Should I pull them apart completely? Another thing to take into account is the decorative edge inside each panel. I'll try to attach photos.
Thanks for your help!
Brimstone077 is offline   Reply With Quote
Old 03-28-2014, 03:09 PM   #2
These are the photos of the doors and openings.
How should I resize my doors?-image-1055336046.jpg   How should I resize my doors?-image-2464061352.jpg   How should I resize my doors?-image-871494233.jpg
Old 03-28-2014, 04:00 PM   #3
Rewards Points: 298
Bi fold doors are pricey and a little clunky too. I didnt feel like paying for bifold door do I put up a curtain on a shower curtain rod. I think it looks good adds some color to wall. I had the stuff laying around so it didnt cost anything.
As far as using the doors together. You could cut them down about 2 inches on each side and hang them as a sliding door. you can get kits separately. That would be easiest but sliders are not very functional.
You can cut down the doors down to 24" and put them back together with glue and dowels. I would make a double door before I would try a bifold.
JustinK is offline   Reply With Quote
Old 03-28-2014, 04:15 PM   #4
Thanks! Im planning to make them solid doors, two on each closet, hinged on one side each. As for sliding doors? I've got a toddler and I've seen them pop off and land on kids before.
The dowel idea is what I'm interested in but was wondering how or where to cut the doors. Do you think 1/2" dowels will hold?
Old 03-28-2014, 04:40 PM   #5
Rewards Points: 298
3 per rail should be fine but dont cut off the hinged side. Measure the rail then cut the door 24 3/4" minus the rail. You will have to router the cut edge of the panel to fit back in rail. But if you dont have one maybe you can use a sander. Find out how far the panel fits into railing and recut door if less than 3/4.. Then cut back just rails so the panel sticks out farther than rails.
Old 03-28-2014, 05:42 PM   #6
Rewards Points: 1,466
I might be inclined to cut a section from the rails to make the desired width, remove the panels and fasten the rails back together with Kreg screws. Also I like the look of louvered doors for that application but I'd need to work on that technique just a bit to incorporate them.
http://www.jeld-wen.com/catalog/interior-doors/louver
Tags
closet door , cutting down , door , resize , resizing
Made My Own Inexpensive Wood Garage Carriage Doors iffy Project Showcase 4 03-31-2012 02:07 PM
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 06:42 AM
Reality check on interior doors recently delivered PatBB Carpentry 8 09-05-2011 05:36 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 05:04 PM
