How To Remove Old Style Baseboards And Quarter Round To Resuse, Without Damaging It? - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-04-2015, 10:18 PM   #16
Rewards Points: 2,452
Leave in place and cut 3-4" above the trim. Remove the square trim on top of red painted trim. It doesn't belong there. Use layers of drywall that come even with existing plaster wall and compound.
Time spent on trying to save/refinish that trim is senseless and wasted time. They are also dry brittle and nailed with 10d trim nail, even the smaller piece on top. You will be breaking them.
carpdad is offline   Reply With Quote
Old 11-04-2015, 09:17 PM   #17
Rewards Points: 254
ghary,
The older style baseboards where wider most likely due to ease of access to run electrical lines. This was a common practice in the early 1900's to the 1950's and beyond in some areas. Nowadays we all know outlets need to be centered 12-18" off the ground in most cases. Having them on the moulding is no longer acceptable.
It also was a lot of just the type of trending style at the time. Now it looks gawdy. If you are spending any sort of substantial time and money on drywall and such, just replace it. It is not hard to make miter cuts, I believe you can even rent a miter saw at a big box store. Trust me, you WILL break some of the moulding..and then you'll have to conjure up a replacement which will not match the original exactly. It's up to you but this is just my two cents, best of luck!
Cheers
mbrando1994 is offline   Reply With Quote
Install Quarter Round when there is large gap underneath the baseboard? Dimeron Flooring 16 05-23-2013 09:35 PM
threshold or quarter round first? sannitig Carpentry 35 11-10-2012 07:48 AM
Miter saw kickback with oak quarter round KukuChoma Carpentry 19 01-11-2012 08:52 AM
Quarter Round for hardwoods - White or match the floor? mr_ekco Flooring 6 02-22-2011 06:00 PM
quarter round + door frame= headache fenceman Flooring 3 02-15-2009 02:28 PM
