How To Remove Old Countertop Supports If I Have To - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-27-2016, 10:36 AM   #1
Rewards Points: 180
How to remove old countertop supports if I have to
These are my old overhang supports. I don't see a good way to remove and replace with something nicer without ripping my wall down. Any ideas? I am fine to leave them I guess, but one seems a tad high and I'm thinking my countertop guy will tell me to lower it and I don't see a good way to do that either.
How to remove old countertop supports if I have to-1474990481021.jpg   How to remove old countertop supports if I have to-1474990545308.jpg   How to remove old countertop supports if I have to-1474990557819.jpg   How to remove old countertop supports if I have to-1474990595335.jpg
jwiens is offline   Reply With Quote
Old 09-27-2016, 10:43 AM   #2
Rewards Points: 7,188
Re: How to remove old countertop supports if I have to
If you are just looking to cut them off flush with the top, a disc grinder will do the job. Maybe even a saws-all with the right blade. You can rent them if you don't have one.
SPS-1 is offline   Reply With Quote
Old 09-27-2016, 12:31 PM   #3
MT Stringer's Avatar
Rewards Points: 254
The counter top installers may or may not use the supports and shim accordingly. They would put down a support board first, then the granite or whatever you are having installed. If not, cut them off.
MT Stringer is offline   Reply With Quote
Old 09-27-2016, 09:31 PM   #4
Rewards Points: 1,514
I'd just keep em.. If they aren't even, they can shim as someone else said.. Will you see them after the countertop is on?
Mine is shimmed.. But you never know cause nobody ever looks underneath
ryansdiydad is offline   Reply With Quote
Remove laminate backsplash georgioltd Remodeling 4 10-17-2012 06:56 AM
Remove very old countertop Heykat Kitchen & Bath Remodeling 3 05-31-2012 01:10 AM
Corian countertop - need to remove glued on metal mike_314 Kitchen & Bath Remodeling 2 03-30-2012 09:09 AM
What do I do with this countertop - suggestions??? cweese Kitchen & Bath Remodeling 11 05-09-2011 06:39 PM
countertop installation - stove/oven issue diycarguy Building & Construction 12 05-04-2009 01:08 PM
