How To Match Base Moulding - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By mark sr
  • 1 Post By alexjburkhardt
Old 08-02-2019, 06:25 AM   #1
Rewards Points: 4
How to Match Base Moulding
Hello,
We are remodeling my daughters new to her house. The house is only 10 yrs old but I cannot find anywhere that has similar base moulding. Re-using existing moulding but had a few break that I need to replace. Any idea how to find a mfg/etc on the attached? Home Depots base mould is not close enough to use. Thought about pulling mould from closets etc to use in the areas needed, then putting Home Depot base in back in the closets but dont want a bunch of splices. Would like to find the same trim.
Any ideas would be appreciated.
How to Match Base Moulding-img_2885.jpg   How to Match Base Moulding-img_2886.jpg
swildman01 is offline   Reply With Quote
Old 08-02-2019, 06:27 AM   #2
retired painter
Rewards Points: 1,352
Re: How to Match Base Moulding
Most builders don't buy their woodwork at a big box store. Check the different lumber and trim suppliers that cater to builders.
lenaitch likes this.
mark sr is offline   Reply With Quote
Old 08-02-2019, 08:08 AM   #3
Rewards Points: 4
Fair point. Good idea thanks.
Old 08-02-2019, 08:21 AM   #4
retired framer
Rewards Points: 18,516
Every manufacture will have a slightly different profile, if you can only get close, change a whole bedroom so you can make your repairs and no one will know.
Do not use flat bottom gables with scissor trusses.
Old 08-02-2019, 10:04 AM   #5
Rewards Points: 122
Unless you find the exact match, splicing two different mfg's profiles together is never going to be clean.
Doing the whole room would be the cleanest. Or at least the continuous sections before they're broken up by door jams, closets, etc.
Inside/outside corner "plinth" blocks can help you transition between profiles, if you must.
alexjburkhardt is offline   Reply With Quote
Old 08-03-2019, 08:01 AM   #6
Rewards Points: 2,273
I would just replace the entire length along the wall where you have breaks. If you are close enough in profile, even if they don't quite match at the corners, it will be hard to tell.
huesmann is offline   Reply With Quote
Old 08-03-2019, 12:24 PM   #7
Naildriver
chandler48's Avatar
Rewards Points: 3,612
In your dreams Height of overall base, profile differences will poke out like a sore thumb. Do the entire room. Too easy and too clean.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 08-04-2019, 09:04 AM   #8
I said "close enough in profile".
