How To Get Rid Of Shelf Paper Sticky Residue? - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-30-2016, 11:49 AM   #1
ZZZZZ's Avatar
Rewards Points: 2,172
How to get rid of shelf paper sticky residue?
I'm re-purposing some kitchen cabinets to create a kitchen island.
I've removed several layers of 20-25 year old Contact-type shelf paper (heat gun and scraper), but there is a lot of really sticky residue left.
I want to paint the shelves but I need to get rid of that sticky residue. I tried the Goo adhesive remover stuff, but that wasn't very effective.
Any suggestions?
Thanks.
ZZZZZ is offline   Reply With Quote
Old 01-30-2016, 12:55 PM   #2
Rewards Points: 14
Maybe some engine bay degreaser from your auto store.
Or a citrus degreaser from home Depot etc
brady5885 is offline   Reply With Quote
Old 01-30-2016, 01:32 PM   #3
Rewards Points: 17,890
Acetone should cut it.
Lots of rags and open the windows when using.
For a 100% sure way to get the paint to stay stuck I'd be stripping back to bare wood.
ZZZZZ (01-30-2016)
Old 01-30-2016, 01:40 PM   #4
ZZZZZ's Avatar
Thanks Joe,
Actually the shelf paper was stuck to the bare plywood shelves. They're nice clean (except for the residue) 5/8" plywood. I think the shelf paper kept the wood in very good shape overall.
My plan is to remove the residue, fill some minor nicks, sand, prime and then paint.
Am I missing anything?
Old 01-30-2016, 01:52 PM   #5
If it's just the shelves I'd prime and use gloss enamel paint.
It's a far harder paint, easy to clean.
Old 01-30-2016, 03:38 PM   #6
JUSTA MEMBER
Rewards Points: 3,624
WD-40 removes a lot of sticky residues.
So will Ammonia cleaner.
I do not know if either will cause paint to not adhere to the wood after use though.
ED
de-nagorg is online now   Reply With Quote
Old 01-31-2016, 09:08 AM   #7
Rewards Points: 996
use brake cleaner
Fix'n it is offline   Reply With Quote
Old 02-02-2016, 09:09 AM   #8
Rewards Points: 2,472
Paint stripper, solvent base, make sure it needs no washing/de-chemical? and do it outside. Use metal wide scraper. Oil base primer, sand, oil base gloss. Let dry at least a week. Cost of material and time may offset buying mellamine boards and edging it yourself. Ask at the store to be cut. Homedepot does acceptable job of cutting parallel boards. Should accept 1/8" difference. Mellamine boards aren't good for spanning over 24" or so.
carpdad is offline   Reply With Quote
Removing Old Stucco Without Damaging Paper greenfrog5 Drywall & Plaster 3 12-31-2012 09:33 AM
sticky tar paper floors N up Building & Construction 3 10-14-2012 06:35 PM
Quick weekend project: Plant Shelf in Foyer hyunelan2 Project Showcase 1 01-04-2012 07:00 AM
how to build toy shelf near ceiling of kids room Kimmoski Carpentry 2 06-22-2011 07:22 AM
why does starter strip have glue on it if it goes on tar paper? KarlJay Roofing/Siding 4 11-24-2010 02:05 PM
