How To Frame For Faucet Plumbing And A Medicine Cabinet - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-26-2016, 03:13 PM   #1
Rewards Points: 2
How to frame for faucet plumbing and a medicine cabinet
I'm doing a bathroom remodel and need some help/advice. I need to reframe a portion of the bath to accommodate a vanity and faucet plumbing along with a medicine cabinet. Problem I am having is the centerline for the plumbing is dead set on an existing stud, and there is the vent stack plumbing running through that area as well. It will be used for the new plumbing in the bath along the wall.
I was thinking of doing studs 16 in on center, on either side of the plumbing centerpoint, and notching them out around the vent plumbing. Finally building out the framing for a medicine cabinet roughly about 6in above the pipe. I think this wall might be load bearing. Which if that is the case, from my understanding you can't notch out a stud more than 20% of its width.
I appreciate any advice you may have.
How to frame for faucet plumbing and a medicine cabinet-2016-07-26-12.07.59.jpg   How to frame for faucet plumbing and a medicine cabinet-tmp_6210-20160726_120648-1321081559.jpg   How to frame for faucet plumbing and a medicine cabinet-tmp_6210-20160726_120700884230237.jpg
Maker is offline   Reply With Quote
Old 07-26-2016, 07:34 PM   #2
Rewards Points: 18,236
Re: How to frame for faucet plumbing and a medicine cabinet
#1, You have old steel plumbing that really should be replaced any way.
At some point it's all going to leak and close up on the inside.
Looks like it's a vent line, cut it off and reroute it it with PVC and hubless connectors.
installing cabinet when counter top is already there phishphan98 Kitchen & Bath Remodeling 1 10-13-2010 08:16 PM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 01:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
