How To Fix The Table? - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-12-2016, 11:52 AM   #1
Rewards Points: 2
How to fix the table?
Hello,
I damaged the table, by "scratching" it quite hard with a wrench. I didn't tear the top part that goes over the wood, but it did separate from the wood beneath it.
I don't really know how the top part is called, or what is it, but hopefully you'll get a better idea from the pictures.
I'm not worried about the small holes in the two pictures DSC04329.JPG, and DSC04330.JPG. Those are here just so that you can get a better idea about what the top part is.
Is there a way to fix this?
Thank you.
Best regards, Grega
How to fix the table?-dsc04326.jpg   How to fix the table?-dsc04327.jpg   How to fix the table?-dsc04328.jpg   How to fix the table?-dsc04329.jpg   How to fix the table?-dsc04330.jpg
gcolnik is offline   Reply With Quote
Old 06-12-2016, 12:51 PM   #2
Rewards Points: 17,890
Re: How to fix the table?
That sure looks like just a vinyl applied over particle board. (like peel and stick shelving paper.)
Looks to thin to be Formica.
Old 06-12-2016, 02:44 PM   #3
Rewards Points: 144
That's what I'm seeing too.Peal it off and apply some new.
mako1 is offline   Reply With Quote
Old 06-12-2016, 08:45 PM   #4
jlhaslip's Avatar
Rewards Points: 708
What size and shape is the table?
It might be easier / cheaper to remove that material and cover with Laminate/Formica/Arborite.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 06-26-2016, 08:47 AM   #5
Rewards Points: 2,472
If last photo shows the edge, and seeing no joint, the cover material must be plastic sheet or maybe even mellamine that is wrapped around the base material. This is not something that can be done diy. Any fix will cost more than the cost of buying another cheap table. If considering formica, it'll be better to just buy another sheet of mdf, build the edge to 1 1/2" with cleats and reattach to the legs. Formica can't be glued to existing cover because the cover does not look stable/permanently attached. Removing the cover may need acetone/paint thinner then repair with filler then sand, etc. Not worth it.
carpdad is offline   Reply With Quote
Tags
kitchen table , wood
How to ... Antique Table and Chairs Restoration? Howitzer General DIY Discussions 13 11-25-2014 08:32 AM
DIY Table Saw vs Ready-Made Table Saw ?? CaptainMarvel Tools 19 01-15-2013 07:21 AM
10" table saw or compound mitre saw - which would you choose? whataboutj Tools 9 12-03-2011 03:13 PM
Tressle table - how to build? Knucklez Carpentry 1 10-24-2009 03:18 PM
Question about table saws,... tribaloverkill Tools 28 04-13-2007 08:47 AM
