How To Find Out If This Are Load Bearing? - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-30-2016, 11:49 AM   #1
Rewards Points: 2
How to find out if this are Load Bearing?
There are 3 collums in my front entry way. I call it a Corral. I want it all removed to open it up. Is there a way to find out without calling an engineer? Thanks
Darse is offline   Reply With Quote
Old 06-30-2016, 12:01 PM   #2
Rewards Points: 107
Those are decorative. Load bearing would be a steel or solid uniform post. These are just railings. I agree they need to go. Kind of wonder what someone was thinking
jimn01 is offline   Reply With Quote
Old 07-02-2016, 11:08 PM   #3
Rewards Points: 2,458
Re: How to find out if this are Load Bearing?
What were they thinking is the point. Supporting posts should be the right kinds of materials but who knows what they were thinking? I wouldn't remove them without knowing what kinds of beams they are. The post under the intersection is esp suspect.
carpdad is offline   Reply With Quote
Old 07-03-2016, 07:00 PM   #4
Framing Contractor
Rewards Points: 50
If this is a one story house, there is a good chance that those might not be supporting anything. If you have access to the roof structure, you may be able to see if you have roof trusses, or a stick built structure. Most roof trusses are supported by the ends only.
sixeightten is online now   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
Gary in WA (07-04-2016)
Creating a 36" door opening on a load bearing wall Solaritu Building & Construction 8 11-03-2014 04:00 PM
Load Bearing Wall Holding up Second Story on Floor Joists HDS Building & Construction 13 10-31-2014 03:33 PM
Closet Walls Load Bearing? - Single Floor Slab with Vaulted Ceiling SteamEngine Building & Construction 3 08-07-2013 10:43 AM
Load Bearing Walls - How To Determine? AngelArs Building & Construction 41 09-19-2012 06:15 PM
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 04:33 PM
