How Do I Finish This? - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-09-2014, 03:25 AM   #1
How do i finish this?
The previous owners to my house had started finishing a closet to a room in the basement. How would I finish the back wall that is concrete? I don't want to leave it like that nor do I want to lose inches by putting up a stud wall.
Tiny207 is offline   Reply With Quote
Old 01-09-2014, 09:23 AM   #2
Rewards Points: 3,130
Where are you located. Might make a difference in vapor barrier requirements. Also, is that wall under, or above, ground level.
How deep it the closet? If you can't live with a stud wall and proper insulation, it's probably too shallow to begin with. I don't know what the "standard" is; the finished depth of mine is 24 inches.
The Following User Says Thank You to md2lgyk For This Useful Post:
joecaption (01-09-2014)
Old 01-09-2014, 10:06 AM   #3
Rewards Points: 17,884
If a vapor barrier and a wall built like it's suppose to be you can plan on anything stored in there to mold up.
Old 01-10-2014, 07:15 PM   #4
Originally Posted by md2lgyk
Where are you located. Might make a difference in vapor barrier requirements. Also, is that wall under, or above, ground level. How deep it the closet? If you can't live with a stud wall and proper insulation, it's probably too shallow to begin with. I don't know what the "standard" is; the finished depth of mine is 24 inches.
Southern Maine. Below grade. I just purchased the house and would like to finish what wasn't completed.
Old 01-10-2014, 07:16 PM   #5
To get this right, if I don't put a wall up I'll have mold in the closet?
Old 01-10-2014, 07:57 PM   #6
Gotcha. Used to live in Wiscassett years ago. Definitely quite a moisture problem in that area.
Old 01-10-2014, 09:31 PM   #7
Warmer moist air hits colder moist wall, poor air circulation, condensates the moisture out of the air, mold forms.
Old 01-11-2014, 08:46 AM   #8
Not the cheapest fix, but you could have that section of the wall spray-foamed.
Old 01-11-2014, 04:06 PM   #9
Handyman
brucem609's Avatar
Rewards Points: 79
Install furring strips, vapor barrier over them and then add in cedar planking. Makes a nice look, and keeps,out the moths
Sent from my iPad using DIY Forum
brucem609 is offline   Reply With Quote
Old 01-11-2014, 05:10 PM   #10
Nothing Unpressure treated should be in direct contact with concrete.
Need help figuring out how to finish knotty pine lizne Painting 12 10-20-2013 01:08 PM
Screen & recoat hardwood with old, possibly waxed finish? TomServo Flooring 0 10-15-2010 04:09 PM
Paint and finish advice for desk addypearce Painting 0 09-03-2010 09:03 AM
Seeking a darker finish for wooden cabinets chibear1986 Painting 8 08-24-2010 11:15 PM
Finish failure SidingHell Off Topic 5 05-20-2010 02:00 PM
