How Do I Build Over A Concrete Slab? - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By SeniorSitizen
Old 10-07-2016, 01:36 PM   #1
Rewards Points: 2
How do I build over a concrete slab?
We enclosed with 2x6 walls and sheet rock our covered patio. We laid ceramic tile over the concrete slab. We are now raising the floor to match the existing floor thru out the house. We are removing the tile and have found there is moisture coming up thru the concrete.
1. Should we try to get as much of the thin set off the concrete prior to sealing?
2. Should we use a RedGard to seal the concrete from moisture?
3. Any particular ml of plastic to lay over the concrete?
4. Should we also treat the concrete wall footing to prevent moisture?
Thank you for your time
redding1996 is offline   Reply With Quote
Old 10-07-2016, 01:56 PM   #2
Rewards Points: 1,466
Re: How do I build over a concrete slab?
Better check the concrete surface temperature when moisture appears to be coming up through the concrete. I'm betting it's surface condensation moisture and I'm broke until my next SS check gets here.
MTN REMODEL LLC likes this.
Old 10-07-2016, 07:41 PM   #3
Rewards Points: 17,884
Little late now, a vapor barrier and foam insulation should have been done under the slab before it was poured.
We have no pictures yet, no location so we have no idea what conditions your having to deal with.
Moisture needs to be dealt with out the outside, not the inside.
Gutters, drain tiles, slope away from the slab, slab at least 6" above grade, ECT.
Concrete Slab repair for plumbing trench dshap1984 Concrete, Stone & Masonry 28 03-03-2015 08:17 PM
Pouring a concrete slab ponch37300 Concrete, Stone & Masonry 11 02-18-2015 05:33 PM
Garage concrete slab / renovation ekfurs Concrete, Stone & Masonry 2 04-24-2014 12:33 PM
Build house on existing concrete slab troyman Building & Construction 6 04-21-2014 05:05 PM
Fix or Replace Porch Concrete Slab Majoram Building & Construction 10 06-25-2011 02:45 PM
