How Do I Attach These Beams? - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-21-2016, 09:21 AM   #1
Rewards Points: 1,236
How do I attach these beams?
I will be extending this gable porch out another 8 feet and want that exposed beam look. The whole thing might have to come down:
Here are two pics I found on the web. My initlal thought was that the beams that are coming out of the house, would lay on top of the top plates. But the more I look at this picture of the guys building the porch, it can't be on the top plate.
Are they simply using a Simpson hanger on wall? Or did they break into the wall and erect a beam pocket? Figured that would be a difficult job since I'd have to fight electrical runs, etc...What are some other ways to do this? Not sure the size of beam I'd be using, but something similar.
Daugela is offline   Reply With Quote
Old 04-21-2016, 10:31 AM   #2
Rewards Points: 144
Re: How do I attach these beams?
To little info.Are you going to pour footings for new post at or close to the end of the addition?The beams to support the roof need to be tied into the existing structure.
What will the span be?
mako1 is offline   Reply With Quote
Old 04-21-2016, 10:35 AM   #3
Here's some more info.
SPAN of beams from house wall to new post: 9'
Width of posts: 13'
Both new posts will have their own footings.
Old 04-24-2016, 02:46 PM   #4
Rewards Points: 2,452
It doesn't matter as long as it is sitting on load bearing points. The first photo, if not the top plates, they could be let into the wall and sitting on multiple studs. Inside wall would have to be cut. The overhang is cut, so there may be a ledger and the sides beams attached to it. The roof sheathing resists the pull away from the house. If you use less rafters, you have to use better sheathing, possibly t&g 2x over the rafters.
carpdad is offline   Reply With Quote
Old 04-24-2016, 08:31 PM   #5
jlhaslip's Avatar
Rewards Points: 708
You could add two new posts/footings next to or near the house and have the beams on 4 posts/footings, sort of like a free standing porch with the roofs connected.
The footings would need to below ground to the same level as the house footings to avoid frost heave issues.
Simpson hangers would only work if there was sufficient framing to attach them properly.
Another option would be to notch the ends so a portion of the beam is on the top plate if the heights don't work. Calculations for beam sizing would tell you if this is an option. It might work, or it might not.
*edit*
You likely won't have frost issues in Arizona LOL
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Deck with insufficient beams. edro Building & Construction 15 11-10-2014 12:40 PM
Attach 4x4 post to 2x4 beam? Biggen Building & Construction 12 01-25-2014 08:48 AM
Gazebo Beams and Joists and Posts power_tree Building & Construction 0 09-07-2013 06:55 PM
Connecting Beams And Post JoeLena Building & Construction 5 01-01-2011 04:32 PM
Garage storage, attaching to engineered beams jdcook72 General DIY Discussions 6 06-16-2009 11:01 PM
