How Close Can A Vanity Be To A Tub/shower? - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By TarheelTerp
Old 11-26-2016, 07:29 PM   #1
Rewards Points: 252
Question
How close can a vanity be to a tub/shower?
What is the code on how close a vanity can be to a tub/shower?
I want to put in a 48" wide vanity. That will leave 12.5" between the vanity and the tub. See attached picture.
How close can a vanity be to a tub/shower?-vanity-tub-space.jpg
John_W is offline   Reply With Quote
Old 11-26-2016, 07:41 PM   #2
Property Mgt/Maint
Rewards Points: 6,368
Re: How close can a vanity be to a tub/shower?
I am not aware of a code that dictates min. distance.
Yodaman is online now   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
John_W (11-27-2016)
Old 11-27-2016, 10:11 AM   #3
Rewards Points: 252
I just found this IRC code that might apply:
"A minimum space of at least 21" must be planned in front of lavatory, toilet, bidet and tub. (IRC R 307.1)."
Here is a drawing from http://starcraftcustombuilders.com/b...m#.WDr9hH352vk. It shows, I guess, that the idea is to make it easy to get into the tub from anywhere along its length.
A 48" x 21" vanity would partially obstruct access to 21" of the the controls end of the tub/shower.
Maybe I'm not interpreting it right or it doesn't apply in this situation.
Old 11-27-2016, 10:37 AM   #4
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,124
Originally Posted by John_W View Post
Here is a drawing from...
Maybe I'm not interpreting it right...
The side to side dimensions shown in that drawing are generous.
More, I don't believe they are reflective of any codes.
The side of a vanity closest to the tub needs to allow some room...
but I doubt that needs to be more than what is left if a toilet (at 36") were there instead... call that 18"c/l less the porcelain or about 11".
hth
John_W likes this.
The Following User Says Thank You to TarheelTerp For This Useful Post:
John_W (11-27-2016)
Old 11-27-2016, 12:08 PM   #5
Rewards Points: 252
hth
That sounds right. Hopefully the inspection department agrees. I will ask them.
A person could use that 11" (or 12.5" in my case) to step between the vanity and the tub and also use the vanity top as a assist in getting into the tub.
A rounded front corner on the vanity top would probably be a good idea too, to minimize injury from a fall against it.
Old 12-01-2016, 07:02 AM   #6
Rewards Points: 2,438
I'm in NJ and I squeezed in a toilet and 30" square shower base where the base overlapped the 15" o.c. toilet space. The sink countertop also overhung the base wall. All passed.
I don't look competent but as long as the inspectors don't find overt incompetencies, they will laugh off little things. I have no idea if there is such spacing rule.
carpdad is offline   Reply With Quote
The Following User Says Thank You to carpdad For This Useful Post:
John_W (12-01-2016)
Old 12-01-2016, 07:30 AM   #7
Rewards Points: 252
Thanks! Our contractor says there is no code for this "closeness" so I'm going for it too.
Vanity pulling away from wall cjaustin81 General DIY Discussions 14 03-15-2015 09:57 PM
Vanity Wall Light - How Close to Ceiling? jman2012 Electrical 6 07-27-2014 09:30 AM
Offset Vanity Tops miltoda Building & Construction 0 12-19-2011 03:29 PM
Installing New Bath Vanity ttammie98 Kitchen & Bath Remodeling 1 08-03-2010 02:39 PM
HELP! Vanity tight squeeze 9728 Kitchen & Bath Remodeling 1 12-11-2009 02:53 PM
