How To Cap Off PL Premium So You Can Reuse It? - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By Windows on Wash
  • 2 Post By ChuckF.
  • 1 Post By Studly
Old 03-06-2017, 04:07 PM   #1
Rewards Points: 383
How to cap off PL Premium so you can reuse it?
Anyone have tips on how to cap off and store PL Premium adhesive, so you can reuse it later? The usual tips for closing off the nozzle (wire nut, screw, making a cap with the adhesive itself, etc.), which work on caulk, don't seem to work on PLP. It always hardens in the plastic nozzle, and I end up having to cut into the cardboard tube to get some out to reuse it.
Studly is offline   Reply With Quote
Old 03-06-2017, 04:20 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,064
Re: How to cap off PL Premium so you can reuse it?
The adhesives that are solvent bases cures will often times leach and still partially cure. Best thing to to make as airtight a tip as possible. Some plastic cling wrap can be used around the entire nozzle, but I suspect you will be disappointed no matter what you do depending on the length of time between uses.
MTN REMODEL LLC likes this.
Old 03-06-2017, 08:37 PM   #3
Rewards Points: 1,742
I use heavy duty aluminum hvac tape, it works fairly well because it doesn't breathe. Go around a time and a half, and then lay the excess on something hard and rub it closed with a tool.
Bud9051 and Str8AheadInc like this.
ChuckF. is offline   Reply With Quote
Old 03-06-2017, 08:49 PM   #4
ZZZZZ's Avatar
Rewards Points: 2,046
I use this general process for all open tubes of caulk, adhesive, etc.
Stick a long stainless steel nail into the tip and then seal the whole nozzle with duct tape. This usually keeps things fresh for up to a couple of months.
When you re-open it, the first squirt or two out of the tube may have hardened or discolored a bit, but clear that out and you should be good to go.
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is online now   Reply With Quote
Old 03-06-2017, 09:58 PM   #5
Rewards Points: 249
I hate the discolored caulk when I use nails. So, I use a stiff plastic tubing. I stick the 2 ends in plumber's putty to seal the open ends. I then stick the tuning into the caulk opening, then bend the end, then wrap cling wrap around the nozzle end and bent tubing, then wrap masking tape to hold the cling wrap.
With plastic tubing, I don't have to do a lot of pre-squirting to get rid of discolored caulk. The first squirt is caulk that's ready to use.
I have latex acrylic caulk that have been open for over a year. They haven't hardened.
I've been wanting to get PL Premium but the tube looks like it's just cardboard. Is it cardboard outside with some coating inside? I use caulk and adhesives sparingly and sometimes a lot depending on my craft or repair project. So, I'd like to be able to reseal efficiently. A seamless plastic tube would fare better at keeping the stuff inside gooey compared to a coated cardboard tube.
Druidia is offline   Reply With Quote
Old 03-06-2017, 10:02 PM   #6
JUSTA MEMBER
Rewards Points: 3,316
Here's what I do.
Insert a 1.5" panhead screw into the opening, wrap the tip with a Baggie, then use a wide rubber band to hold the baggie on.
Later (sometimes months), pull the rubber band, remove the bag, it often tears, it's trash anyway.
Get a pliers and pull the screw and dried plug out.
You now have an opened tube of PL ready to go.
ED
de-nagorg is offline   Reply With Quote
Old 03-07-2017, 02:27 PM   #7
Rewards Points: 383
Thanks for the tips, everyone!
de-nagorg likes this.
Old 03-12-2017, 08:59 AM   #8
Rewards Points: 2,356
I stopped using urethane caulk, which has shorter life span than other kinds. I think urethane caulks have expire dates on the tube somewhere. Don't buy unless you see this. I've had good luck with making 2" tube around the nozzle with any kind of tape, squeeze some into the tube, pinch the end closed then pressurizing the tube. Air gets pushed out and the nozzle end is just about capped closed by its own caulk.
carpdad is offline   Reply With Quote
Jeld-Wen Premium cibula11 Windows and Doors 6 09-18-2013 09:28 PM
Olympic Premium Flat and Semi-Gloss Ultra White fozzie Painting 15 12-07-2009 08:20 PM
Behr Premium Plus Ultra beachnik Painting 2 06-15-2009 04:36 AM
tiling with PL premium tonia Tiling, ceramics, marble 5 05-14-2009 08:23 AM
Storing PL Premium construction adhesive Nestor_Kelebay General DIY Discussions 14 12-19-2008 07:03 AM
