High Celings A Problem! Solution? - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-17-2014, 10:58 AM   #1
High Celings a Problem! solution?
Hi There! I am going to go on and say that I am NOT a DIY' by any means But Before I call someone out I would like to get opinions from people who are! =)
Ok heres my problem... Our living room has high ceilings. It is almost impossible to keep the home warm in the winter and cool in the summer (peak months of course) We have had someone come out and do all of the things to try and fix this problem. (ac unit upgrade,ducts cleaned,windows sealed ect ect.) Also its just a lot of unused space. When we first bought the home it was a WOW factor but now that we have lived in it for a few years, not so much anymore.. I have thought maybe to lower the celings.. Add another room above then just extend the ducts. (again im not entirely sure you can even do these things!) Here are a few pictures.
In the second picture you can see a ledge that already has a solid floor. i have no idea why? but the back wall is the wall of the spare bedroom.
Thanks again! any information would help!
Jsmaria is offline   Reply With Quote
Old 05-17-2014, 04:37 PM   #2
Retired Moderator
Rewards Points: 7,174
I decked over part of my two story great room---you will need to get an architect,designer or engineer to draw up the plans--but ,yes--it can be done.
I've also lowered the ceilings in several customers rooms---That is a simple process--
venting problem needs solution. jverge Roofing/Siding 7 12-27-2011 08:18 PM
American Standard intermittent inducer problem with presssure switch warning no such user HVAC 5 12-26-2011 05:20 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Chimney has simple problem - complicated solution Leah Frances General DIY Discussions 6 03-18-2008 04:52 PM
Simple problem that requires a complex solution. wfischer Electrical 18 01-07-2008 12:21 PM
