Help With Unique Drywall Outside Corner - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-13-2017, 02:02 PM   #1
Rewards Points: 2
Help with unique drywall outside corner
I have two half walls at the entrance into my shower with an outside corner over 90 degrees. (see picture below, only one shown) One side has regular drywall and the other side has cement board that bullnose tile will go to finish off the edge. What is the best way to finish off this corner? I tried a rounded bullnose bead but they only make it in vinyl and it cannnot bend that far.
I can remove the cement board and resize it if I need to. I can also move the cabinet out of the way.
Should I just fill it in with mud or use a metal corner bead and bend it to the correct angle? PLEASE help!
Help with unique drywall outside corner-img_0753.jpg   Help with unique drywall outside corner-img_0754.jpg
Ericmturbo is offline   Reply With Quote
Old 08-13-2017, 04:36 PM   #2
Rewards Points: 5,810
Re: Help with unique drywall outside corner
My question is, how do you want to finish that edge? Bringing the two surfaces out to a narrow point doesn't seem good or attractive. One option might be to make it a blunt ending like cutting the more extended piece back a bit.
They make a super wide paper faced metal corner but I'm not sure if that is the solution you want.
http://www.homedepot.com/p/Phillips-...FU4pPwodc14L-A
Bud
Bud9051 is offline   Reply With Quote
Old 08-13-2017, 11:11 PM   #3
retired framer
Rewards Points: 18,764
That kind of thing looks good in the imagination, I would rebuild the corner to be just a normal end of wall.
Old 08-14-2017, 05:43 AM   #4
retired painter
Rewards Points: 1,426
.... or at least knock [cut] the point off of the corner.
mark sr is online now   Reply With Quote
Old 08-14-2017, 05:51 AM   #5
Naildriver
chandler48's Avatar
Rewards Points: 3,666
Combining the comments, I would flatten the joint out and use two paper/metal corners to complete the angles, one on each side, since it will be too wide for a single corner piece. http://www.homedepot.com/p/Strait-Fl...t-90/202579261
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 08-21-2017, 09:07 PM   #6
Rewards Points: 2,146
There is some nice cornerbead out there you cant get at lowes or home depot. its a plastic core with paper ends... you can make alot of wierd angles with it 'work'
Check contractor supply houses for it.
That Guy is offline   Reply With Quote
Old 08-21-2017, 10:46 PM   #7
retired framer
Drywall corner not square plandis Drywall & Plaster 8 06-16-2015 07:18 PM
Drywall Pocket Door Wall Near a Corner TeeRiddle Drywall & Plaster 2 05-16-2015 04:30 PM
Repair Outside Corner Drywall in Bath mollylibby Drywall & Plaster 5 07-01-2012 09:51 AM
Drywall Mudding Challenge: Seam vs. Tapered Corner cjakins Drywall & Plaster 3 03-10-2009 12:41 PM
corner drywall, tiling issue DIYRook007 Remodeling 4 04-21-2008 11:51 AM
