Help With Stiffening An Attic Floor For Finishing - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-05-2013, 09:38 PM   #1
Help with Stiffening an Attic Floor for Finishing
Hello,
I have a balloon framed two story colonial with an unfinished walk up attic. I'd like to floor the attic, possibly finish in the future as an office room, don't plan on adding a ton of live weight.
I'm looking for advice on the best way to stiffen and support this attic floor before laying a subfloor
The first and 2nd floors are 2x10 floor joists. The attic joists are 2x8. Everything 16 OC
The attic joists span 14' and 13' meeting in a middle beam.
The 2nd floor ceilings are plaster, in good shape
There is a good deal of electric and insulation between the joists and getting long 2xs up to the attic to sister beams is not possible.
questions:
1) Do I need further support or can I simply start laying 3/4 plywood (or OSB)
2) I looked into laying 2x4s on their face across the joists (where the knee walls would eventually go) and tying them to the gable end wall studs. (Ribbands right?) and I could further support by making stongbacks.
My concern with strongbacks is whether it really does any good without a top plate to distrubute the load.
3) Concerning laying the floor, 3/4 plywood is best? I'd rather use OSB for cost reasons but if plywood is lighter and stiffer thats probably a better way to go.
And the 4x8 boards will need to be cut to get them up the stairs, for stength/stiffness is 2x8 lengths or roughly 4x5 boards better?
Any advice is much appreciated. Thanks.
Last edited by TheEplumber; 11-07-2013 at 12:06 AM. Reason: advertising link removed
agentbarnes is offline   Reply With Quote
Old 11-06-2013, 11:29 PM   #2
Registered User
Rewards Points: 526
The answers are on page 2 of your building permit papers/permit for the structural changes and liability for your HO Insurance carrier.
Gary
PS. Welcome to the forums!
Insulation in the attic when the furnace is up there Jimmybrp Insulation 2 12-11-2011 02:26 PM
Attic - Replacing electrical - Positioning, how many boxes, checking understandings darlingm Electrical 12 12-04-2011 11:17 PM
Can I mount a window A/C into the wall, exhausting to the attic? Greg2230 HVAC 2 06-01-2010 08:56 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
