Help With Removing Very Old Linoleum Under Floor - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-04-2019, 09:30 PM   #1
Rewards Points: 2
Unhappy
Help with removing very old linoleum under floor
I have a heat gun and have been removing some very old linoleum. I discovered that there is tile under the linoleum and whatever they used 50 years ago to stick the base to isnít coming off easy. Heat helps but itís brutal. It almost seens like they used a cement glue or something. Is there any sort of chemical that might make the job easier? I tried an iron and the heat gun and the heat gun was effective at removing the linoleum but not so great with the vinyl bare. Thanks.
Piuskid is offline   Reply With Quote
Old 01-04-2019, 10:21 PM   #2
retired framer
Rewards Points: 18,478
Re: Help with removing very old linoleum under floor
duplicate.
Nealtw is offline   Reply With Quote
Old 01-24-2019, 12:35 AM   #3
Rewards Points: 484
Rent one of the machines that have a power driven blade to separate the flooring from the subfloor. Walk behind scrappers like the Bartell sell for around $1500 so the daily rental should be less than $100. With the 9" wide blade the work will go pretty fast.
Slower is to use a scrapper on a pole or if you have a SDS hammer drill (or you can rent one) there are special floor scrapper bits but these are 3" or 6" wide and so it will take a lot more time.
Calson is offline   Reply With Quote
Old 03-02-2019, 02:18 PM   #4
Rewards Points: 448
Are your sure the old flooring is not asbestos? Consider laying 1/4" luan plywood over the existing flooring and install your new floor.
Let it Snow is offline   Reply With Quote
Tags
floor linoleum painful
How to seal old floor after removing linoleum tiles, before carpeting wklkj Flooring 9 01-15-2018 09:13 AM
Coat Closet with Angled Floor l008com Carpentry 13 11-08-2017 04:58 PM
Removing Concrete Basement floor. Dennis Brown Building & Construction 5 11-04-2017 09:10 AM
Removing Floor in Sunroom thoon1 Building & Construction 4 02-04-2016 12:52 AM
Removing Linoleum backing paper from wood floors SatDoug Flooring 4 09-16-2006 11:00 PM
