Help, Need More Cabinets But Don't Know The Brand! - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-24-2015, 01:31 PM   #1
Rewards Points: 6
Help, need more cabinets but don't know the brand!
We've just moved into an apartment that was half-completed by the previous owner. We have some nice cabinets in the kitchen and need more to finish the job, but since they're installed, I can't find out the brand to get more! Is there a way to determine the brand?
Photo attached if anyone can identify!
Thank you!
matthewinnyc is offline   Reply With Quote
Old 01-24-2015, 01:39 PM   #2
Rewards Points: 582
Happy to post pictures if anyone might be able to identify them.
Thank you!
post away need to see them
Old 01-24-2015, 01:40 PM   #3
Rewards Points: 6
Thanks - just added a photo!
Old 01-24-2015, 01:43 PM   #4
Rewards Points: 582
did you look inside doors or drawers to see if it tells you....how about local places were you can buy cabinets see if it came from there take a door off and try to match it up
Old 01-24-2015, 01:51 PM   #5
Rewards Points: 6
We looked inside doors and drawers and didn't see anything. Is there another spot to look? We figured it might be on the back but that may be impossible since they are installed now.
Old 01-24-2015, 04:39 PM   #6
gdc
member
gdc's Avatar
Rewards Points: 168
cabinet brand
hi matthewinyc, it looks like a quaker door design, and the boxes are framed. the color is typical, coffee or moca just my guess on finish, but close to it. what im saying is you can find cabinets to match easily. take one of the doors to match color and style. age of cabinets could be an issue. look at the side of the cabinet bottom edge do you see plywood or partical board. are the sides of the cabinets laminate ( not plastic ) but kind of like a film. all that will be needed to get the cabinets to finish your project. now I know that's not answering your question directly but its a start. oh and look at the shelf pins and holes. cab co. use different pins and could narrow it down. manufacturers could be kraftmade, woodmode, Thomasville etc. what is your location. my reason for asking is I see you have nyc. I can give you quite a bit leads on where to check out.
gdc is offline   Reply With Quote
Old 01-25-2015, 06:14 AM   #7
gdc
member
gdc's Avatar
Rewards Points: 168
cabinet brand
sorry ben I just saw you also suggested taking the door also. my bad !!
Old 01-25-2015, 08:29 AM   #8
Rewards Points: 6
Hi GDC - thanks! I just found the name Winwood imprinted on the bottom of one of the cabinets. That appears to be a company in New York but I don't see them for sale anywhere. Any thoughts?
Thanks!
Old 01-25-2015, 09:38 AM   #9
Rewards Points: 996
they could have ordered them online. but first, you should check around at the building supply places.
Fix'n it is offline   Reply With Quote
Old 01-25-2015, 12:45 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If only you had a computer you could do a search for Wynnwood Cabinetry and see what pops ups. I found them...can you?
XXX
Old 01-25-2015, 01:33 PM   #11
MT Stringer's Avatar
Rewards Points: 254
Is the cabinet mounted sideways? Asking for help by posting a pic sideways is not the way to go. Really. Folks will help but you got to do the work.
MT Stringer is offline   Reply With Quote
Tiles before or after kitchen cabinets? nipab Remodeling 9 01-05-2015 11:19 AM
New Cabinets sweaty General DIY Discussions 9 09-14-2011 06:09 PM
Picking cabinets, does anything decent exist? 1320ms Kitchen & Bath Remodeling 12 06-08-2010 11:48 PM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-20-2008 11:32 PM
Excessive shimming to keep wall cabinets flush with one another? alexz Carpentry 10 12-22-2007 07:48 PM
