Help Me Figure Out Shower Valves - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By Calson
Old 06-05-2019, 03:02 PM   #1
Help me figure out shower valves
Hello everyone. First post so forgive any mistakes. I'm trying to figure out how to design the shower I am building in place of a large tub and giant platform around it. I get the pros/cons of thermostatic/pressure reducing valves, but isn't a thermostatic valve going to function the same as a pressure reducer with a flow control valve downstream of it?
If I am looking for multiple shower heads to run on the same temperature, couldn't I just tee off above the mixing valve and then use fancy looking flow control valves to determine which shower head(s) gets the water? Water efficiency flow reducers are typically installed at the head itself, right, not the mixing valve?
Any insight on this would be helpful 🙂
Mhays02 is offline   Reply With Quote
Old 06-05-2019, 04:33 PM   #2
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,136
Re: Help me figure out shower valves
Originally Posted by Mhays02 View Post
I get the pros/cons of thermostatic/pressure reducing valves, but ...
And they're required by code.
If I am looking for multiple shower heads to...
Select the package/group of fixtures/valves all from one company.
Old 06-12-2019, 09:09 PM   #3
Rewards Points: 484
The installation guide for the valves and jets should show a diagram for a manifold with a balancing loop, or you can find an example online. A balancing loop is designed to insure that there is equal water pressure to each jet or shower head. You end up using a lot more pipe but it is what is needed and it is a one time job and so worth doing it right.
georgemcq and lug-nuts like this.
Calson is offline   Reply With Quote
