Help Me Choose A Layout For My Basement Remodel (Pictures Attached) - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-12-2012, 05:57 PM   #1
Help me choose a layout for my basement remodel (Pictures attached)
Help me choose! Basement remodel
Hey guys, we have an unfinished basement that we are going to finish and we have a few ways we can frame it. We need at least 1 bedroom and my wife wants a scrapbooking room. There are 2 ways to frame it but we can't decide on which one. 1. We would frame the bedroom against the 1st bedroom but we would be walking into the hallway at the bottom of the stairs. 2. We would frame the front of the basement (w/ the bump out of windows, same bump out on top, split level) and we would have somewhat of an open basement. I have attached some pictures to help. Thanks!
Last edited by oh'mike; 08-12-2012 at 08:29 PM. Reason: Removed link to competing forum---don't do that agaiin please
danreg99 is offline   Reply With Quote
Old 08-13-2012, 07:51 AM   #2
Rewards Points: 288
To answer your question directly, between those two options, I prefer the first, where you come down into an open area. Make the back room the bedroom and the bay window room her scrapbooking room.
Personally I don't like walking down into a hallway which is why I dislike the second option. Can you get away without having that door at the base of the stairs? What is the room behind the bathroom? I assume utilities?
moneymgmt is offline   Reply With Quote
Old 08-13-2012, 09:17 AM   #3
Money, thanks for the feedback. The door behind the bathroom is the utility room. Do you see any other way to frame this? I guess I am pretty limited.
Old 08-13-2012, 09:25 AM   #4
Rewards Points: 288
As my grandfather says, you are only limited in life by your wallet and your imagination! I would rather have the big beautiful bay window as a part of the main entertaining area rather than a scrapbooking room that nobody sees, but yes, you are a bit limited. In option 2, could you move the bar to the opposite side where the table is, and take out the wall between that room and the staircase? Why the small room next to the stairs?
Old 08-13-2012, 09:34 AM   #5
Rewards Points: 766
I like the second option if you get rid of the wall between the bar and the stairs. Is the bump out at the bottom of the pic facing the front of the house? Where is the sun coming from?
B
Beepster is offline   Reply With Quote
Old 08-13-2012, 09:47 AM   #6
Money, the small room next to the stairs is actually under the stairs going up and is about 4' ft tall. I don't really want to cover up the front windows but then I have to deal with a hallway. I guess there are pros and cons. Beepster, the bay windows are at the front of the house facing the west (bay goes all continues thru the second story). Maybe I will just tell the wife no scapbook room.
Old 08-13-2012, 10:01 AM   #7
DIY-er
Here is a layout that mirrors the common area witht the stairs attached to the main living area ...... and has a window in every room.
Help me choose a layout for my basement remodel (Pictures attached)-basement-layout.jpg
KevinPh is offline   Reply With Quote
Old 08-13-2012, 10:19 AM   #8
Rewards Points: 1,330
Something to kep in mind with basements is tight/narrow doors and corners. It makes it hard to move furniture in and out when needed. I have a basement staircasein my house that is a straight shot from the entry door. I can not get furniture into the basement due to a narrow door at the top of the stairs. fortunatly, I have a Bilco entry at the back of the house that will allow me to get big stuff in. However, there is a tight corner I have to navigate around to get into the living area.
danpik is offline   Reply With Quote
Old 08-13-2012, 10:24 AM   #9
Kevin, we have thought of that as well but the main plumbing stack is being hidden in bedroom 1 closet.
Old 08-13-2012, 11:23 AM   #10
Rewards Points: 3,130
Just be sure that bedroom has an egress window.
Old 08-13-2012, 12:03 PM   #11
Yes, it is a daylight basement so the slider windows is about 3-4 feet off of the ground.
Old 08-13-2012, 12:46 PM   #12
Rewards Points: 288
I thought Kevin was really onto something there, I like that layout. Does the "bedroom 1 closet" show up on your diagrams? Obviously I don't know how big what you're trying to hide is or how big the rooms are, could you frame tighly around it without putting it in a whole closet?
Old 08-13-2012, 02:22 PM   #13
Money, I forgot to add the closet in bedroom 1. The plumbing stack will be in the front framing of the closet. It is out about 16 inches from the foundation wall and is 4" pvc. How would you frame around that to look half ways decent?
Old 08-13-2012, 07:47 PM   #14
Rewards Points: 600
Originally Posted by moneymgmt View Post
... I prefer the first, where you come down into an open area...
Me too, in fact can you double the width of the stairway? Make the downstairs flow just like any other level of a split level home.
puttster
puttster is offline   Reply With Quote
Old 08-14-2012, 12:20 AM   #15
Rewards Points: 2,262
Because of the stairs I would go with option 1.
More open feel.
Make the Bay window room the bedroom and the smaller room the scrap booking room?
In laws had similar to option 2 and it worked OK.
mae-ling is offline   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Basement Remodel Shaotzu Project Showcase 2 04-27-2011 06:50 AM
Adding Circuit for basement remodel ksl Electrical 3 01-10-2011 08:58 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Control Dust in Basement Remodel Siamese Remodeling 4 03-19-2008 02:47 PM
