Help For Framing Utility Room - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 12-11-2017, 05:02 PM   #1
Rewards Points: 12
Help for framing utility room
Guys,
I am trying to DIY basement and encounter this difficult situation in framing around a utility room.
I can nail the studs to the ground but unable to nail it to the ceiling joists as there are pipes and large AC vents. There is not enough room to use nail gun on the ceiling neither.
Is there any idea to get around it?
Help for framing utility room-img_1952.jpg   Help for framing utility room-img_1954.jpg
Dorian05 is offline   Reply With Quote
Old 12-11-2017, 05:45 PM   #2
Guapo
Rewards Points: 11,950
Re: Help for framing utility room
The biggest mistake that people make is that they don't leave enough room for servicing the equipment. The pipes & vents need access. Do you plan to finish the entire lower level? What about a partition instead of a permanent wall?
Guap0_ is offline   Reply With Quote
Old 12-11-2017, 06:32 PM   #3
Rewards Points: 12
That's a fair point. There would be enough room for servicing (one of my original pictures shows the rough location of the bottom 2x4s), but most likely not for replacement.
Eventually yes, the room adjacent to the utilities will be a movie theater, I could hide an extra access to the theater behind a movie screen.
I want a wall for a better finish. I don't think it will host any sort of load besides probably the drywall and sound insulation. my worry is around anchoring that wall to the ceiling with so many utilities up there.
Old 12-11-2017, 06:40 PM   #4
Mike Milam's Avatar
Rewards Points: 152
This is how I dealt with mine.
Dave Sal likes this.
Thank a police officer for being the one who runs 'TO' a report of shots fired, while everyone else runs 'AWAY'
Mike Milam is offline   Reply With Quote
Old 12-11-2017, 06:50 PM   #5
retired framer
Rewards Points: 18,776
Build the wall under the steel beam first. You can shoot the nails into the beam.
The wall below the duct work is built short enough to fit below the ducts. If you finish a ceiling in that room and when you finish the room outside that wall you have to build drops to hide all that too.
https://www.lowes.com/pd/DEWALT-Sing...-Tool/50200049
Old 12-11-2017, 06:50 PM   #6
Rewards Points: 12
So build the soffit first and then anchor the top of the frame for the wall to the soffit? I never thought about it this way.
Mike Milam likes this.
Old 12-11-2017, 06:52 PM   #7
Guapo
One of you pics is rotated which makes vBulletin famous. My chiropractor will fix my neck. Anyway, I would suggest a 36" door to that room.
To solve the stud problem, just nail a few vertical pieces where possible. Then nail a top plate to them & connect the studs there.
Old 12-11-2017, 06:53 PM   #8
retired framer
Looks good, we used plywood, osb for the drops instead of the 2x4 blocks, easier to level the bottom 2x4.
Old 12-11-2017, 06:57 PM   #9
Rewards Points: 12
What kind of nails should I use? I already have a powder actuated nail gun (https://www.homedepot.com/p/Ramset-M...0088/202046595).
Old 12-11-2017, 07:05 PM   #10
Rewards Points: 12
Sorry about the neck, mine is sore looking at that ceiling scratching my head
The biggest stud issue is between the two vents, there's barely 2 inches and already my refrigerant pipes.
Old 12-11-2017, 07:06 PM   #11
Mike Milam's Avatar
Rewards Points: 152
I'm bad about over doing things.
Old 12-11-2017, 07:13 PM   #12
retired framer
I don't see anything over done there, lot's of framers build them just like you did.
The Following User Says Thank You to Nealtw For This Useful Post:
Mike Milam (12-11-2017)
Old 12-11-2017, 07:17 PM   #13
Rewards Points: 12
Thanks everyone.
I'll start with the wall under the steel beam, just because I am not comfortable with soffits yet. I also need to keep openings big enough in the walls to be able to replace the heater/tank/furnace in the future.
Old 12-11-2017, 07:27 PM   #14
retired framer
You need a door on this side for the water tank and a maybe a double door on the other side for the hvac.
When you have two apposing walls the end wall is easy enough.
Old 12-11-2017, 08:12 PM   #15
jlhaslip's Avatar
Rewards Points: 708
I have seen MDF used for those bulkheads drops and painted instead of drywalled. Caulk the joints. Done.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Draining appliances in Utility room shaken Plumbing 4 11-19-2016 03:17 PM
water heater in unheated utility room momof2labs HVAC 24 12-14-2012 05:25 AM
Utility Room MLayden Electrical 3 04-10-2012 10:14 AM
sound proofing utility room BlueBSH Drywall & Plaster 29 12-24-2009 12:44 PM
Freeze protection in utility room? akguy HVAC 1 11-20-2009 05:30 AM
