Help With Back Splash Tile Of Different Thickness - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-29-2017, 01:49 AM   #1
Help with back splash tile of different thickness
Hi, Have been completely remodeling my kitchen for the past couple weeks. Whenever I'm needing some direction, I'm usually directed to this site. It's been of tremendous help, thanks.
I'm almost finished and one of the last things to do is install the back splash. The tile purchased for the job is 12x12 mosaic glass sheets and 3x6 glass subway tiles.
The design will be - 6 lines of the mosaic, 2 rows of the 3x6, then 6 lines of the mosaic. Right around 19" tall when finished.
The issue is that the mosaic is 4mm thick and the subway is 8mm thick. The wife is dead set on this particular mosaic and I can't find the glass subway that's 4mm. So, this is what's gonna be used.
My question is what is the easiest, cheapest, best way to get these flush? lol
It's my understanding that the thinset for the 4mm mosaic would be pretty thin to begin with. So, I don't think it's smart to make up the difference by going heavy on the thinset. If I can, without issue, tell me and problem solved!. If that's not a good choice then what should be done?
I've read using 1/4" backer board or or some ditra will work (although some advise against using ditra with small mosaic). The ditra seems very expensive and I'd rather use that as a last resort.
Would it be safe to build up the areas with thinset by 1/4" or just shy of that, let it dry for a few days and then install the back splash?
ANY help, suggestions, or advice would be greatly appreciated. THANKS
thatsreality is offline   Reply With Quote
Old 10-04-2017, 03:30 AM   #2
Rewards Points: 4,212
Re: Help with back splash tile of different thickness
Just my opinion.
I have used similar to this with good results.
http://www.homedepot.com/p/Underlaym...1178/203183010
ron45 is offline   Reply With Quote
Old 10-04-2017, 04:56 AM   #3
Rewards Points: 898
http://floorelf.com/setting-differen...le-for-inserts
BIG Johnson is offline   Reply With Quote
Tile lippage-acceptable or not? KC33 Tiling, ceramics, marble 10 12-04-2015 02:33 AM
Back Door tile spacing? Fireplace tile spacing? greentrees Tiling, ceramics, marble 2 08-24-2013 08:14 PM
Tile setting Bed Thickness pctaber Tiling, ceramics, marble 1 12-23-2011 09:37 AM
unlevel floor and diff. thickness wall tile bryan1282 Tiling, ceramics, marble 2 08-08-2011 09:26 AM
Tile Back splash over stove - Waste of time? Mr Chips Flooring 5 07-06-2008 01:46 PM
