Header Beam - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By 3onthetree
  • 2 Post By Nealtw
  • 1 Post By jsmith1107
Old 03-03-2019, 01:44 PM   #1
Rewards Points: 222
Header beam
I am working on a remodeling project, and for those of you who are on this forum a lot, yes I am asking a lot of questions. Just trying to get my ducks in a row so when it actually warms up in Wisconsin I can start on my project.
Anyway--as you can see in the picture I have a couple of supports on this wall and thinking about a couple of things--1. maybe want to open the wall up completely and if so, how big a header would I need (supporting wall)? 2. thinking maybe about putting an island in like the picture---I should be able to do that rather easy because I have those three openings already (as you can see in the pictures) but I would probably change it to 2 openings.
Thoughts?
AND YES, the house is very outdated. haha
jsmith1107 is offline   Reply With Quote
Old 03-03-2019, 06:33 PM   #2
Hammered Thumb
Rewards Points: 1,826
Re: Header beam
I'm sure you already know that's bearing probably splitting a 24' wide house down the middle like most. Any size opening is possible, so come up with your kitchen plan first so you know the exact opening you want and whether you can live with columns like in the example. Also verify the basement beam, column support, and roof structure and give all the info to a structural engineer or a lumberyard who uses one.
Then you gotta find a re-use for those railings, maybe like for a ladder toss game?
SPS-1 likes this.
3onthetree is offline   Reply With Quote
Old 03-03-2019, 07:51 PM   #3
Rewards Points: 222
Re: Header beam
Yeah, that is quite the look on that house right now isn't it? haha.
Thanks for the info.
Old 03-03-2019, 09:05 PM   #4
Rewards Points: 2
Re: Header beam
Quite the design they made there. I would talk you your local code enforcement office and nail down their requirements. After that check with a local lumber yard to help you spec an LVL. This is all quite easy to do and can probably be done using the LVL manufacturers published span tables.
Sent from my SAMSUNG-SM-G930A using Tapatalk
NEMick is offline   Reply With Quote
Old 03-03-2019, 09:17 PM   #5
retired framer
Rewards Points: 18,620
Re: Header beam
Basement, crawl space. How is this supported. If it is a wall on a footing, the fear is over loading spots on a footing not designed for that.
Yodaman and NEMick like this.
Do not use flat bottom gables with scissor trusses.
Old 03-07-2019, 10:54 AM   #6
Rewards Points: 222
Re: Header beam
right below this wall is the supports in the basement.
Old 03-07-2019, 11:10 AM   #7
retired framer
Re: Header beam
So the beam was designed to carry a load over the span, then the question is will it handle the same load that is landing in one or two areas between the posts in the basement. That looks like 2x12s laminated to make a beam, for over kill you could just add another layer to that, the load on the posts does not change.
It would be reasonable to match the size of this beam to the one upstairs if the one upstairs is not longer than the same section downstairs.
When you load the floor upstairs with 3 jacks and a king stud, make sure you come down and put solid blocking between the joists to support that 6" right down to the beam.
Old 03-07-2019, 11:19 AM   #8
Rewards Points: 222
Re: Header beam
I could put another post in the basement beneath the wall to help support it couldn't I? Basically, I am looking to get rid of the two end beams (in the top picture). The two middle ones will still be there as in the picture above of the beautiful kitchen.
Old 03-07-2019, 11:23 AM   #9
retired framer
Re: Header beam
That would require a footing below the floor.
I think you said you were leaving 2 posts at the island, where would they land on the beam in the basement. I really don't think you have big deal here.
Old 03-07-2019, 11:48 AM   #10
Hammered Thumb
Re: Header beam
Looks like the stair is to the right of the living and the basement lally falls about under that upstairs post with the outlet.
If you're just eliminating a post to give like a 6' or 8' opening, more than likely the basement structure could be sufficient. If you were to span the whole living room, then the basement beam would have to be looked at.
Old 03-07-2019, 01:14 PM   #11
Rewards Points: 222
Re: Header beam
perfect, thanks guys. BTW, now I have a window question in the window section of the forum. haha
Nealtw likes this.
Header beam sizing for new walls WillK Carpentry 4 08-21-2017 09:20 AM
beam replacement and sistering Bamboozler Building & Construction 22 06-20-2016 12:01 PM
Which beam is stronger? D270 Building & Construction 19 04-19-2012 07:17 AM
Need to determine proper Basement Window Header size- AdamH Building & Construction 1 11-23-2011 02:59 PM
Garage Header rwbil Building & Construction 11 09-16-2010 11:50 AM
