Hate These Towel/toilet Paper Holder Hardware... - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree6Likes
  • 1 Post By lenaitch
  • 1 Post By ron45
  • 3 Post By SPS-1
Old 09-16-2018, 06:16 PM   #1
Rewards Points: 14
Not sure what you call these but they use to use a screw to tighten them up if they got loose. About two years ago we replaced them in a couple of bathrooms and they use this metal piece instead that starts to give way and jostle over time. Do all of the holders use this now or do some still have the kind that you can use an Allen wrench and screw to tighten?
Hate these towel/toilet paper holder hardware...-a5ee439a-2aee-4f2f-b61e-3574a65cda74_1537139803293.jpg
ajwired is offline   Reply With Quote
Old 09-16-2018, 06:33 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 2,028
Re: Hate these towel/toilet paper holder hardware...
I'm not familiar with the mount in your picture but many manufacturers still use a fixture that is locked to the wall bracket with a set screw. However, your problem might not be the fixture's fault. It looks like the wall bracket is loose. Perhaps a larger anchor or relocating the fixture to a slightly new location will do the trick. I recently had the same problem at my daughter's new place. Their TP holder was loose and my efforts with larger anchor plugs just made it worse. I found a stud about 3" away and now it's not going anywhere.
ajwired likes this.
_________________________________________
Who Dares Wins
lenaitch is offline   Reply With Quote
Old 09-17-2018, 09:21 AM   #3
Rewards Points: 14
The bracket is firmly mounted to the wall so that's not it. It's the metal pieces that don't hold it securely. Might just have to shop intentionally for one that uses a set screw.
Old 09-18-2018, 05:39 PM   #4
Rewards Points: 4,180
Maybe.?
https://www.hayneedle.com/product/de...CABEgKkPPD_BwE
ajwired likes this.
ron45 is offline   Reply With Quote
Old 09-18-2018, 06:14 PM   #5
Rewards Points: 7,196
All the holders in my house use a rigid steel bracket on the wall, and the mating piece has a cone tip set screw at the bottom to lock it in place. Never had one come loose.
Hate these towel/toilet paper holder hardware...-toilet-paper.jpg
lenaitch, Mike Milam and ajwired like this.
SPS-1 is online now   Reply With Quote
Old 09-19-2018, 06:55 AM   #6
Rewards Points: 14
That's an idea. Thanks.
Old 09-19-2018, 06:57 AM   #7
Rewards Points: 14
Yep this is the type I would prefer. I bought these from Lowe's. Can recall if they are a Moen or something else. Guess I'll be the crazy dude opening the package to see if it uses a set screw or not. LOL Or I'll have to find one I like and look up the tech spec/install instructions before purchase to double check.
Old 09-19-2018, 09:32 PM   #8
Usually Confused
lenaitch's Avatar
I can't say I've seen a bracket like your original photo. I do recall a post quite a while ago regarding a plastic bracket that snapped on (or something like that - it's been a while) and did not hold well. The bracket shown by SPS-1 is the type I am familiar with.
ajwired likes this.
Who Dares Wins
why does starter strip have glue on it if it goes on tar paper? KarlJay Roofing/Siding 4 11-24-2010 02:05 PM
Towel rod and toilet paper holder dnbreaks Remodeling 4 01-30-2010 03:24 PM
Can't get set screw in TP holder loose janralix Plumbing 4 08-12-2009 10:47 PM
Felt Paper and the Sun. Valley problems hartkem Roofing/Siding 1 07-22-2009 03:57 PM
contact paper removal scatterbrain Remodeling 2 07-06-2008 07:57 AM
