Half Wall With Spindles - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By joecaption
  • 1 Post By KPDMinc
Old 01-08-2017, 05:34 PM   #1
Rewards Points: 4
Half Wall with Spindles
Hello. I am new to the forums, but hoping to get some great input on some of the many projects that would get my 1980's home up to date. Consider me a complete amateur when it comes to handyman, common-sense maintenance type items. One way thing that I am looking to do is remove these spindles from the entry way. Is it safe to assume these are non load bearing and if so, what would the best steps for removing them be in order to not destroy the half wall or the ceiling?
JAyer1654 is offline   Reply With Quote
Old 01-08-2017, 09:40 PM   #2
JUSTA MEMBER
Rewards Points: 3,476
Re: Half Wall with Spindles
Those are usually put together like a puzzle.
Look closely at either the bottom or the top for a plug glued into a hole, usually the wood grain wont align perfectly, giving an idea where to drill the plug out.
They are usually screwed in on one end, (the top) with a double wood screw, one end in the spindle the other into the frame.
Then the other end has a "toed" hole that a screw is used to screw it solid, then a plug glued into the hole covering the screw head. and trimmed flush and finished with a finish.
Might take a bit of examination, but you will find attachment points somewhere.
ED
de-nagorg is offline   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
JAyer1654 (03-26-2017)
Old 01-08-2017, 10:17 PM   #3
Rewards Points: 17,882
Classic 60 to 70's.
There not doing anything.
Ed has more patients then I have.
I'd just knock them out with a hammer, make the repairs and move on.
Going to have to do the repairs anyways.
Mike Milam likes this.
de-nagorg (01-08-2017)
Old 01-08-2017, 10:26 PM   #4
JUSTA MEMBER
Thanks Joe.
I see them as useful somewhere else, thus I strive to re-use things like that.
OP could just use a sawz-all in the middle of them and saw them in half, then rip them out, but as you say repairs will be needed then.
ED
Old 03-26-2017, 05:36 PM   #5
Rewards Points: 4
Thanks for the responses. I did not see a plug and I am able to slightly twist, which makes me believe their is not a screw going in at an angle. So are all indications pointing to sawz-all or demo with hammer?
Old 03-26-2017, 07:12 PM   #6
jlhaslip's Avatar
Rewards Points: 708
Cut them about 3 inches from the bottom so as to miss the screw and you may be able to salvage them if you so desire. Otherwise, it doesn't really matter where you cut them.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 04-02-2017, 08:16 PM   #7
Professional
Rewards Points: 188
Yeah, those are decorative and can be ripped out. Re-use? I don't know about reuse for something so dated. Free stuff on Craigslist maybe. Did you rip them out yet?
Str8AheadInc is offline   Reply With Quote
Old 04-03-2017, 07:49 AM   #8
Rewards Points: 692
I'd use an oscillating multi tool with a plunge blade to cut them off at the very top and bottom. This will do the least amount of damage to the spindles. If you're not sure if there are metal fasteners involved get a blade that will cut both wood and metal. If you don't have an oscillating multi tool you can get a cheapy ($15.00) at Harbor Freight or buy something better if tools are in your budget. This is a really cool tool. Bosch blades are tops......but be aware that different tool manufacturers use different attachment configurations....but there are adapters.
JIMMIEM is offline   Reply With Quote
Old 04-13-2017, 06:20 PM   #9
Rewards Points: 232
Rip them out, re-purpose them into firewood...
2sents likes this.
KPDMinc is offline   Reply With Quote
Need Some Advice About A House With An Issue neutropia General DIY Discussions 7 01-29-2017 06:46 AM
Basement half wall tekmonkey Building & Construction 1 12-24-2015 10:51 AM
Securing a Half Wall cbaur88 Building & Construction 18 02-18-2013 05:43 PM
Half wall help rodsteryz Remodeling 2 02-18-2012 12:11 AM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
