GROUTABLE Vinyl Tiles In Shower? - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-17-2018, 05:08 PM   #1
Rewards Points: 2
Question
GROUTABLE Vinyl tiles in shower?
I know this sounds crazy, but why wouldn't it work?
I'd like to install vinyl groutable tiles for my shower walls, and use acrylic grout. (over Green/Blue/Purple drywall)
I would think this would be water tight. I'd probably go with a full shower pan instead of tile floor, just to be safe.
So am I crazy to try it?
tcrimsonk is offline   Reply With Quote
Old 08-17-2018, 05:31 PM   #2
Rewards Points: 17,890
Re: GROUTABLE Vinyl tiles in shower?
I would never use any form of drywall in a shower area no matter what there ads say.
Judging from just my own experiances I've been payed many times to remove those cheap plastic tiles that where all the rage back in the 70's.
Most often there main reason was all the cracked tiles from being bumped over the years.
Will it likely work, yes, will it look like cheap plastic tile, also yes.
Done right a real tile job will add value to the home and last for generations.
Old 08-25-2018, 03:08 PM   #3
Bob Sanders's Avatar
Rewards Points: 2,536
I've used vinyl sheet flooring in shower stalls before (floor and walls) which works fine. Not sure I would use vinyl tile though. Too many joints to go wrong.
Covfefe!
Bob Sanders is offline   Reply With Quote
Replace engineered hardwood floor by vinyl tiles french_guy Flooring 35 07-26-2015 07:31 AM
Vinyl window in shower: has grout up against vinyl - should caulk have been used? lazzlazz Tiling, ceramics, marble 1 12-04-2014 04:15 AM
Sanded or unsanded grout for the shower surround wall tiles? nitting Tiling, ceramics, marble 10 11-30-2012 08:45 AM
Vinyl floor tiles on vinyl floor Project423 Flooring 2 02-27-2012 01:04 PM
Asbestos in shower tiles??? sydneymath Kitchen & Bath Remodeling 16 03-15-2011 09:16 AM
