Grout In Tiles - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-10-2016, 09:03 PM   #1
Rewards Points: 180
Grout in tiles
I'm trying to fix my 1946 bathroom. I pulled the wallpaper, but they put paper in prior to tiling the tub. Then they used what I assume is grout to fill between the end tiles and the wall. I think that is normally supposed to be silicone right? In any case they got a bunch on the tiles too. I don't plan on redoing the bath or tiles. Any ideas on how I can get it off? Do I need to try to remove the grout where silicone should go next to the wall? Thanks.
jwiens is offline   Reply With Quote
Old 10-10-2016, 09:09 PM   #2
Rewards Points: 180
Re: Grout in tiles
Also this section of wall just pulled off easily. Can I just fix that with mud?
Old 10-11-2016, 05:58 PM   #3
Retired Moderator
Rewards Points: 7,174
Re: Grout in tiles
Yes, you can fix that with mud---I suggest 20 minute 'easy sand'---
Silicone should NOT be used where the tile meets the painted wall---paint will not stick to 100% silicone---use a good painters caulk or a grout color match caulk.
Sanded or unsanded grout for the shower surround wall tiles? nitting Tiling, ceramics, marble 10 11-30-2012 08:45 AM
thinset between tiles in grout space amakarevic Flooring 2 06-10-2011 04:29 PM
Darkening grout colour between polished marble tiles TLea Kitchen & Bath Remodeling 6 03-19-2010 07:46 AM
Tiles cracking, popping, grout falling out. Mojomama Flooring 8 03-19-2009 08:50 AM
calking backer board to tub glassman General DIY Discussions 13 06-19-2008 08:41 PM
