Grout Or Caulk? - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree12Likes
  • 1 Post By Windows on Wash
  • 1 Post By stick\shift
  • 1 Post By ChuckF.
  • 1 Post By ChuckF.
  • 1 Post By gwlaw99
  • 1 Post By txblaster701
  • 2 Post By RickMacKay
  • 1 Post By MTN REMODEL LLC
  • 3 Post By kwikfishron
Old 02-17-2017, 07:31 PM   #1
Grout or Caulk?
Hey guys,
Looking to redo the sealant in my shower and I don't know if this is grout or caulk. New to DIY and would love pointers on how to remove this and what to replace it with.
Any pointers on tools, what to buy, etc would be helpful!
txblaster701 is offline   Reply With Quote
Old 02-17-2017, 07:36 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,330
Re: Grout or Caulk?
It should be caulking.
MTN REMODEL LLC likes this.
Old 02-17-2017, 10:45 PM   #3
Rewards Points: 4,110
Re: Grout or Caulk?
Always caulk changes in plane.
stick\shift is offline   Reply With Quote
Old 02-18-2017, 09:11 PM   #4
Rewards Points: 1,746
Re: Grout or Caulk?
Caulk, and look for a better color match.
ChuckF. is offline   Reply With Quote
Old 02-18-2017, 09:39 PM   #5
Grout or Caulk?
It is hard like grout and doesn't peel away. How do you get this stuff off?
It's also cracked, as you can see in this pic. Does caulk crack?
Like I said, I'm new to this, so thanks for the insight, DIY Gurus!
Old 02-18-2017, 11:19 PM   #6
Re: Grout or Caulk?
Could be grout, sometimes grout is misused in corners like that. It matches the grout in color. Could be old hardened latex caulk. It's not silicone, silicone doesn't crack, it gets moldy underneath and starts to peel.
To remove, get single-edged razor blades and a holder, and scrape in from both directions.
txblaster701 likes this.
Old 03-06-2017, 02:45 PM   #7
Rewards Points: 8
Re: Grout or Caulk?
caulk
gwlaw99 is offline   Reply With Quote
Old 03-06-2017, 06:00 PM   #8
Re: Grout or Caulk?
Yes, I found out that it's sanded caulk - you can buy it at lowes
Old 03-06-2017, 08:31 PM   #9
Re: Grout or Caulk?
Caulk, if you want it off, use a soap scum remover, cut it with a razor blade which will make it easier to peel away with a putty knife or chisel. After you got most of it, use an alcohol soaked rag to help ease the rest away. We commonly deal with this.
Concrete Contractor Rocklin
Brookely is offline   Reply With Quote
Old 03-11-2017, 02:39 PM   #10
RickMacKay's Avatar
Rewards Points: 114
Re: Grout or Caulk?
The only thing I would add is that is a sloppy caulk bead. Sanded caulk is harder to lay down straight vs. un-sanded caulk. I fire tradesmen who leave a mess like that. Before you re-caulk, lay down some blue tape to get a nice straight line for the caulk. Yes, tape the vertical and horizontal. Caulk, tool it in with a wet finger, and peel away the tape. Amateurs might lay down too much caulk-----you want it thin where the tape is. Also, be SURE the tape is down tight, rub it good with your thumb, this will prevent excess from sliding under the tape. And when you peel off the tape, pull it away from the caulk bead, not towards it.
kwikfishron and txblaster701 like this.
RickMacKay is offline   Reply With Quote
Old 03-11-2017, 09:49 PM   #11
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,054
Re: Grout or Caulk?
Rick....
Just honestly.... I am no great artisan.... but do you really tape off a caulk joint....?
I will say you need a good caulk gun with which you can lay down an even bead.
To the OP.... Just scrape it off and replace.
MTN REMODEL LLC is offline   Reply With Quote
Old 03-11-2017, 11:02 PM   #12
kwikfishron's Avatar
Rewards Points: 288
Re: Grout or Caulk?
I sure do with tub/shower, back-splashes and in many cases where paint meets stain.
With tape and the proper technique you can achieve a caulk-line that looks as if it was factory.
kwikfishron is online now   Reply With Quote
Old 03-12-2017, 09:05 AM   #13
Re: Grout or Caulk?
Thanks for the advice!! New caulk went on great and even. Really appreciate the help, gents.
Tile around tub - grout, caulk, or other? Joe F Kitchen & Bath Remodeling 3 04-25-2016 05:43 AM
Are you supposed to caulk your grout? (Bathroom tiles) Mathlete General DIY Discussions 7 11-08-2013 06:52 PM
grout or caulk l-bracket shorteared Building & Construction 2 09-22-2012 09:59 AM
Grout pulled out alond with caulk on tub easybay Plumbing 0 04-09-2010 11:01 AM
Grout replaced with caulk by tile guy? Johnsonj General DIY Discussions 4 03-12-2010 04:09 PM
