Grille Over A Smoke Detector - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By u3b3rg33k
Old 08-02-2018, 10:06 AM   #1
Rewards Points: 6
Question
Grille Over a Smoke Detector
Hoping for some help here... I have dropped my ceiling about 3 inches (from the original concrete ceiling) in order to fit wiring and pot lights between the new drywall and original concrete.
Mounted on the original concrete ceiling is a smoke detector and heat detector. I am thinking to cut the drywall out of my new dropped ceiling to expose the smoke detectors and to put a grille on the cutout so that smoke and heat will still be able to reach them.
Is this allowed?
I am located in Ontario.
cwwatt is offline   Reply With Quote
Old 08-02-2018, 11:31 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 23,470
Re: Grille Over a Smoke Detector
My instinct says no. The smoke and heat will most likely need to be relocated to the new ceiling.
Old 08-02-2018, 01:47 PM   #3
Rewards Points: 6
Thanks!
My instinct does as well... hoping somebody familiar with fire code / regulation could give a firm yes or no.
Old 08-02-2018, 02:59 PM   #4
Rewards Points: 626
I'd say drop the detectors to the new level. Most install instructions say to not put detectors too near the junction of a wall and ceiling as this is often a dead air space with little circulation. Also with the detectors tucked in between the two ceilings the alarm sound will be muted.
Also for ease of changing batteries and testing.
daveb1 is online now   Reply With Quote
Old 08-02-2018, 07:50 PM   #5
Usually Confused
lenaitch's Avatar
Rewards Points: 2,004
Good point about muting the sound. From the Ontario Building Code:
The Ontario Building Code | Smoke Alarms
3.2.4.22. Smoke Alarms
(4) A smoke alarm shall be installed on or near the ceiling.
Admittedly not great clarity to help you but I doubt behind the ceiling would be effective or compliant.
_________________________________________
Who Dares Wins
lenaitch is offline   Reply With Quote
Old 08-03-2018, 07:13 AM   #6
Rewards Points: 6
Thanks guys... I agree - I can't find any specifics in the code. Technically it would still be installed on or near a ceiling... would just have a grille in front of it.
Old 08-03-2018, 11:03 AM   #7
Rewards Points: 1,084
they obviously mean on the ceiling, or near the ceiling (on the wall). if you remove common sense, then on the floor upstairs would also count as "near the ceiling".
lenaitch likes this.
u3b3rg33k is offline   Reply With Quote
Old 08-25-2018, 03:14 PM   #8
Bob Sanders's Avatar
Rewards Points: 2,536
He said "detector". Not sure if that's what he meant but there is a difference between a smoke detector and a smoke alarm... a detector doen't make sound.
Covfefe!
Bob Sanders is offline   Reply With Quote
Tags
alarm , detector , fire , grille , smoke
AFCI, smoke detector and outlets Calab Electrical 17 10-12-2017 11:17 AM
Smoke Detector Placement.... NorPlan Safety 20 10-15-2016 09:05 AM
Smoke detector install help cpgoose Electrical 5 02-19-2014 11:07 AM
Smoke Detector in Drop Ceiling Hiro Remodeling 16 09-28-2013 03:41 PM
Smoke detector in garage? BlueBSH Electrical 6 03-18-2010 02:57 PM
