Getting Sheetrock Boards Up To 3rd Floor Condo - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-20-2014, 12:43 PM   #1
Rewards Points: 1,077
Getting sheetrock boards up to 3rd floor condo
I have a small (535 square feet) one-bedroom condo which is unfortunately on the 3rd floor.
I'm going to be getting a new ceiling in all the rooms (except bathroom).
The sheetrock boards are 4 feet by 8 feet. While we might be able to get them up via the tight staircase, I was wondering whether I could tie a sheetrock board to a rope or something and pull it up to my roof deck from the ground outside the building.
I'm thinking this might be easier then using the staircase which has some sharp turns.
If I used this method then I would have to be careful not to damage the vinyl siding on the side of the building.
I was wondering whether anyone has ever used this method and if so, what did you use? Bungee cord?
Below is a photo of my roof deck taken from the ground level.
stripedbass is offline   Reply With Quote
Old 09-20-2014, 01:11 PM   #2
Rewards Points: 454
Get it delivered by a drywall supply co. they can boom it up
scottktmrider is offline   Reply With Quote
Old 09-20-2014, 01:22 PM   #3
Rewards Points: 144
Scott has the right answer.You can't tie a rope around it and pull it up.It will tear the hell out of the sheetrock.
mako1 is offline   Reply With Quote
Old 09-20-2014, 02:27 PM   #4
Rewards Points: 18,230
Often times a window is removed and the boom truck can load it right through the window.
Any real sheetrock company I've dealt with even sends a crew to do all the work of unloading it off of the boom and placing in the room.
A whole lot less seams to deal if you can use 12' pieces not 8's.
Old 09-20-2014, 02:31 PM   #5
Rewards Points: 454
The past few years If I place a big drywall order with a small lumber yard they will sub it out to a big supply house. its not worth their time
How many sheets are you talking
Old 09-20-2014, 04:07 PM   #6
Renovating My Land Yacht
Rewards Points: 616
We went through a local supply house and there was no additional charge for the boom...actually it was pretty cool how they did it but they wouldn't let me drive
They also beat the big box on price significantly.
forcedreno2012 is offline   Reply With Quote
Old 09-20-2014, 04:10 PM   #7
Rewards Points: 144
Now your learning.Good luck with the project.Keep us updated.
Old 09-20-2014, 09:39 PM   #8
Going to rent a drywall lift, right?
Makes it a whole lot easier.
Old 09-21-2014, 08:40 PM   #9
Hi Folks,
As always, I'm really grateful for all your feedback.
Something occurred to me. We recently had the building's main roof replaced.
Tomorrow the same roofer comes to remove the deck you see in the photo and replace the rubber roof underneath it, then later build a whole new deck for my neighbor and I.
I'm not 100% sure but I seem to recall that when the roofer rebuilt the main roof his crew had a horizontal ladder that could go up. But maybe that's just my memory playing tricks with me.
I'm going to watching the roofer very closely in case he has something that I could use to get the sheetrock up.
Otherwise, I will have to carefully weigh all your interesting suggestions and see what I can do.
I really appreciate the feedback.
Old 10-15-2014, 01:02 AM   #10
Rewards Points: 978
southern hospitality. up here no way
federer is offline   Reply With Quote
Deck Boards and Deck Size Earnie Building & Construction 6 09-12-2011 09:38 PM
Fitting newer laminate floor boards to older obsolete ones... Ricklesss Flooring 2 07-29-2011 03:33 PM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 05:26 PM
sheetrock over sheetrock add insualtion? monkeywrench Remodeling 18 11-30-2008 10:19 AM
New medicine cabinet--old plaster and sheetrock help! garyofnyc Remodeling 4 10-31-2008 11:15 PM
