DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Remodeling (https://www.diychatroom.com/f15/)
-   -   Getting sheetrock boards up to 3rd floor condo (https://www.diychatroom.com/f15/getting-sheetrock-boards-up-3rd-floor-condo-206771/)
stripedbass 09-20-2014 12:43 PM
I have a small (535 square feet) one-bedroom condo which is unfortunately on the 3rd floor.
I'm going to be getting a new ceiling in all the rooms (except bathroom).
The sheetrock boards are 4 feet by 8 feet. While we might be able to get them up via the tight staircase, I was wondering whether I could tie a sheetrock board to a rope or something and pull it up to my roof deck from the ground outside the building.
I'm thinking this might be easier then using the staircase which has some sharp turns.
If I used this method then I would have to be careful not to damage the vinyl siding on the side of the building.
I was wondering whether anyone has ever used this method and if so, what did you use? Bungee cord?
Below is a photo of my roof deck taken from the ground level.
http://i647.photobucket.com/albums/u...psaee9ebc8.jpg
scottktmrider 09-20-2014 01:11 PM
Get it delivered by a drywall supply co. they can boom it up
mako1 09-20-2014 01:22 PM
Scott has the right answer.You can't tie a rope around it and pull it up.It will tear the hell out of the sheetrock.
joecaption 09-20-2014 02:27 PM
Often times a window is removed and the boom truck can load it right through the window.
Any real sheetrock company I've dealt with even sends a crew to do all the work of unloading it off of the boom and placing in the room.
A whole lot less seams to deal if you can use 12' pieces not 8's.
scottktmrider 09-20-2014 02:31 PM
The past few years If I place a big drywall order with a small lumber yard they will sub it out to a big supply house. its not worth their time
How many sheets are you talking
forcedreno2012 09-20-2014 04:07 PM
We went through a local supply house and there was no additional charge for the boom...actually it was pretty cool how they did it but they wouldn't let me drive :(
They also beat the big box on price significantly.
mako1 09-20-2014 04:10 PM
Now your learning.Good luck with the project.Keep us updated.
joecaption 09-20-2014 09:39 PM
Going to rent a drywall lift, right?
Makes it a whole lot easier.
stripedbass 09-21-2014 08:40 PM
Hi Folks,
As always, I'm really grateful for all your feedback.
Something occurred to me. We recently had the building's main roof replaced.
Tomorrow the same roofer comes to remove the deck you see in the photo and replace the rubber roof underneath it, then later build a whole new deck for my neighbor and I.
I'm not 100% sure but I seem to recall that when the roofer rebuilt the main roof his crew had a horizontal ladder that could go up. But maybe that's just my memory playing tricks with me.
I'm going to watching the roofer very closely in case he has something that I could use to get the sheetrock up.
Otherwise, I will have to carefully weigh all your interesting suggestions and see what I can do.
I really appreciate the feedback.
federer 10-15-2014 01:02 AM
southern hospitality. up here no way
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
