General Contractor Vs Restoration Contractor - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-15-2016, 02:00 PM   #1
Rewards Points: 28
General Contractor vs Restoration Contractor
Does anyone know the difference between the two?
giterrdone is offline   Reply With Quote
Old 02-15-2016, 03:20 PM   #2
Super Moderator
Gymschu's Avatar
Rewards Points: 6,742
I've worked for both types as a painting sub. The only difference is that the Restoration guys know a lot more about dealing with the insurance companies.
"In the heat of battle, my father wove a tapestry of obscenity........."
Old 02-15-2016, 05:27 PM   #3
Rewards Points: 17,884
The more info you give the better the replys.
What is it your needing done?
New home, restoring an old house, addition, repairing storm or fire damage?
Old 02-15-2016, 07:11 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,474
In the old antique homes, a contractor wants to totally replace parts, where a restoration carpenter wants to keep the parts as close to original as possible by repair or reproducing, using antique materials, instead of replace.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 02-15-2016, 08:38 PM   #5
Rewards Points: 469
Restoration will cost a lot more then a GC, Most historic homes have set rules to follow and the cost can double or more then normal construction
Jnaas2 is offline   Reply With Quote
The Following User Says Thank You to Jnaas2 For This Useful Post:
BigJim (02-16-2016)
Old 02-18-2016, 01:50 PM   #6
Rewards Points: 28
I was thinking along the lines of water damage or general reconstruction after a storm. I feel like restoration contractors could potentially be more expensive. But it those cases you have your homeowners issurance. Anybody have experience working with a restoration company like Serv Proor DKI http://www.dkiservices.com/...or Should I go with more of a local type contractor?
Reputable/Affordable South Jersey General Contractor AMSx2 Building & Construction 1 02-25-2015 07:26 AM
General Contractor fees Luvbug Off Topic 15 08-21-2013 08:28 PM
license requirements to become a general contractor in Illinois billiesellshome New Member Introductions 1 07-26-2012 04:20 AM
What You Should Know Before Hiring Any Contractor!!! DangerMouse Roofing/Siding 0 07-08-2012 08:31 AM
Choosing a contractor Grumpy Remodeling 7 04-28-2011 07:29 AM
