Garage Conversion Plans - Water Heater, Etc... - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By jlhaslip
Old 01-15-2018, 08:14 PM   #1
Garage Conversion Plans - Water Heater, etc...
Hello, I'm looking at doing a garage conversion and had some concerns about what to do with an existing water heater. We have a water heater in the garage and not too sure on what ventilation is needed for it. It sits in the corner of our garage and is a 40,000 BTU water heater. The garage also has a vent (See below) that we are not too sure of what it is used for but we assume it is to ventilate the water heater. Our plan was to build a wall 5 ft out from the garage door which will create a separate area for the water heater and the vent (See below). Is this a good option? Or is there a better one that will save us some space? Thanks
Here's the vent:
Here's the water heater:
Here's a map of what we plan to do:
draik161 is offline   Reply With Quote
Old 01-16-2018, 09:11 PM   #2
Rewards Points: 4,210
Re: Garage Conversion Plans - Water Heater, etc...
I would want mine in the house.?
ron45 is online now   Reply With Quote
Old 01-16-2018, 10:13 PM   #3
jlhaslip's Avatar
Rewards Points: 708
Totally agree, but he might live in the Tropics.
Because there is what looks like a vent on the top, I assume the water heater is gas powered. If so, you will need a source of fresh air as combustion air to burn as the heater gets fired. That would explain the vent.
Nealtw likes this.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 01-28-2018, 09:39 PM   #4
Sorry I didn't follow up on this in a timely matter.
I would still want the heater in the house near it's destination. The longer the run the more money it will cost.
New hot water heater issue with water quality and potential resolutions biggerdaddynj Plumbing 11 04-13-2016 10:17 AM
A Water Heater, an Outlet, a Cable and a Breaker Koldhammer Electrical 1 02-19-2015 04:43 PM
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 08:48 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
