Garage Ceiling/door Opener - Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Kvsmith*1959
Old 01-10-2018, 11:38 AM   #1
Rewards Points: 4
Garage ceiling/door opener
Hi,
New to the forums. Looks very helpful.
I am getting ready to insulate and hang drywall in my one car detached garage which I will be using as an office. I want to keep the ability to open the garage door using the electric opener. I don't really want to look at the opener and am wondering if I can box it in somehow. The track leading to the opener I'm assuming I can build a long box above it so that it is recessed somehow?
Have never done this (garage conversion) so am looking for some ideas on how to cover the ceiling with insulation and drywall but keep the functionality of the garage door. Any ideas?
Thanks!
Kevin
Garage ceiling/door opener-garage-ceiling.jpg
Kvsmith*1959 is offline   Reply With Quote
Old 01-10-2018, 03:45 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 2,038
Re: Garage ceiling/door opener
I'm not sure why the sight of the opener would be a bother but to each their own. I suppose you could build a box around it so long as you allow for airflow so it doesn't overheat. Also, a box might interfere with a remote control. As for boxing "above" the track, I must be missing something as to how that would accomplish anything. The track cannot be boxed in since it has to remain open along the bottom to allow the arm connected to the door to travel. If you mean that you want to recess the track into a ceiling, you would be limited to the distances and clearances of the connecting hardware - the track and door connecting arm have to the be within a set distance from each other.
It's a garage, that you are using for another purpose but retaining the function of the door, but don't want to see it. I don't think you can square those circles.
Edit - You can get openers that act directly on the tension rod - the motor and mechanism mount at the side near where the track bends. I don't think they are all that common for residential use and imagine they are pricey.
_________________________________________
Who Dares Wins
lenaitch is offline   Reply With Quote
Old 01-10-2018, 03:55 PM   #3
retired framer
Rewards Points: 18,758
We have added an office door and window in the doorway a few times always the garage door was just left in the up position.
Drywall is usually put up first, so working around it would be a pain too.
You will want to add box vents or ridge vents and make sure air can make it from the soffet area with chutes.
Old 01-10-2018, 04:25 PM   #4
Mike Milam's Avatar
Rewards Points: 152
This may be of some help, albeit pricey. But likely less expensive than trying to hide a conventional opener.
https://www.amazon.com/LiftMaster-85...ter+8500+elite
Thank a police officer for being the one who runs 'TO' a report of shots fired, while everyone else runs 'AWAY'
Mike Milam is offline   Reply With Quote
Old 01-10-2018, 06:38 PM   #5
Rewards Points: 1,406
Just me, but if it was mine I would drywall the ceiling, no box. When you sell the home in the future, no more DIY projects to undo.
Then, close on each side of the GO, I would hang down from the ceiling my favorite state flag, ball team flag, big pictures of my first car or favorite family photos or scenes.
Or, (with blocking done to hang them from before covering the ceiling with DW) I would maybe hang a 24" small flat screen TV on each side of the GO.... for "around the room" viewing of the game.
Gregsoldtruck79 is offline   Reply With Quote
Old 01-10-2018, 07:37 PM   #6
Rewards Points: 4
Thanks everyone! Makes sense. I think I was trying to make it harder than it needed to be
Nealtw likes this.
The Following User Says Thank You to Kvsmith*1959 For This Useful Post:
Mike Milam (01-10-2018)
Converting garage attic into light storage space lixepoc Building & Construction 7 01-05-2018 12:45 PM
Adding subpanel to Garage jimmyfloyd Electrical 2 11-09-2012 09:22 AM
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 06:42 PM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 10:32 PM
