Freestanding Tub - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-23-2014, 08:52 PM   #1
freestanding tub
A COUPLE OF QUESTIONS. i BOUGHT A FREESTANDING TUB, IT HAS 4 LEGS WHICH I WILL LEVEL. THERE ARENT ANY OTHER BRACKETS, CAN I APPLY LIQUID NAILS TO THE BOTTOM OF LEG SUPPORTS AND MOUNT IT TO FLOOR, ALSO THE DRAIN IS JUST A HOLE, THE DRAIN PIPE COMING OUT OF THE FLOOR LINES UP WITH IT BUT I NEED TO CONNECT HOLD TO DRAIN PIPE, WHAT DO I USE? ANY HELP WOULD BE MUCH APPRECIATED.
nyjetfan is offline   Reply With Quote
Old 03-23-2014, 10:31 PM   #2
Rewards Points: 17,890
Going to need pictures and a lot more info.
Cast iron tub? If so no adhesive needed.
No one here can see what you have for a drain, so it's hard to tell you how to connect it.
Deck; Partially Attached Partially Freestanding? wewantutopia Building & Construction 2 02-11-2014 03:38 PM
Freestanding deck has some lateral movement? MikeVila Building & Construction 7 05-28-2012 12:54 PM
Building a deck, attached or freestanding? NewHomeDIYGuy Building & Construction 28 04-19-2012 06:16 PM
Freestanding range to cooktop + oven combo. Lots of data (kw, wiring, etc) made2last Electrical 12 04-07-2012 12:19 AM
freestanding tub filler w/standup shower amakarevic Plumbing 9 10-05-2011 10:04 AM
