Framless Shower Door With NO Studs - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-17-2016, 12:33 PM
Rewards Points: 6
Framless Shower Door with NO Studs
Hi, I've recently neared completion of a bathroom remodel. I took it down to the studs and put it back together, however, I didn't plan well enough for the shower door. I was hoping for a frameless shower door but did not put studs behind the tile.
I had the plumber set the shower pan. I put up hardibacker, Redgard, and tile. I'm wondering if there are anchors strong enough to hold a frameless glass door? The opening is 34 3/8" wide.
The door I'm looking at is OVE Decore Shelby on Lowes.com for $500.
Am I s*** out of luck and have to go with a framed door?
hamiltop2015 is offline
Old 08-17-2016, 08:46 PM
firehawkmph's Avatar
Rewards Points: 2,452
Re: Framless Shower Door with NO Studs
Any way of going in from the other side of the wall and adding a stud and/or some blocking? Got a pic or two?
Mike Hawkins
firehawkmph is offline
Old 08-17-2016, 08:51 PM
Rewards Points: 6
No. It is an exterior wall. I have white subway tile (3x6) on the shower wall and wood siding on the other side.
Old 08-18-2016, 06:54 AM
You might want to check with a local shop that specializes in glass and custom shower doors and see what they recommend for fasteners. They may have something that will work.
Mike Hawkins
Old 08-18-2016, 08:09 AM
Rewards Points: 6
Thx. Probably is my best bet.
Tags
bathroom , frameless shower doors , no studs , tile
Vinyl shower walls, cut to size, glue to studs, caulk joints? gunner666 Kitchen & Bath Remodeling 4 07-16-2015 06:05 AM
Basement bathroom shower remodel NewHomeDIYGuy Kitchen & Bath Remodeling 39 11-26-2013 10:20 AM
Shower Leak Herk_Man Plumbing 10 04-14-2013 04:19 PM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 12:04 PM
creating new shower floor/ slope??? Bob Funk Plumbing 2 03-01-2010 04:22 PM
