Framing A Wood Studded Wall Against A Concrete Block Wall - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-07-2014, 11:55 AM   #16
DIYer
Rewards Points: 302
It is STILL going to be a garage. But I spend more time in the garage than I do in the house. I'm doing full insulation, wall board, cabinets, shelves, counters, new doors, heat/AC. But still a car shop.
mystic_cobra is offline   Reply With Quote
Old 01-10-2014, 05:20 AM   #17
Mark the spot on the floor where the wood anchor will be located. Drill holes through the wood with a bit the diameter of the anchor sleeve
michelclarke is offline   Reply With Quote
Old 01-10-2014, 06:38 AM   #18
DIYer
Rewards Points: 302
I was planning to use a ramset with nails.
Old 01-10-2014, 07:41 AM   #19
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,260
House has vented brick veneer and good overhangs. There is no issue with moisture.
No additional vapor barrier required on the interior other than the foam.
Old 01-10-2014, 10:57 AM   #20
Rewards Points: 582
removed comment....ben sr
Old 01-10-2014, 10:59 AM   #21
DIYer
Rewards Points: 302
His project is hopefully done by now, but I'm still working on mine.
I think I have all that I need to get the plans finished up and get the permit application underway. Hope to start building within the week.
Old 01-18-2014, 01:47 PM   #22
Professional
TotalHomeworx's Avatar
You should still have a gap between the concrete and wood even above grade for moisture. This will also help to plumb the wall. Put building wrap on the walls first. This stops moisture but allows it to breathe. You need to have a gasket under the bottom plate (foam or 6mil plastic) or use pressure treat lumber as bottom plate to protect from moisture. You can do 16 or 24" centers, 18" centers will not work with the insulation or drywall. If it is a garage, then I would use moisture resistant drywall or exterior grade plywood to cover the studs, insulation and vapor retardant (6mil poly).
TotalHomeworx is offline   Reply With Quote
Old 01-21-2014, 09:20 AM   #23
DIYer
Rewards Points: 302
Thanks for the tips!
wood framing end wall on a steel building jackofnotrades Building & Construction 7 10-12-2014 10:54 AM
How to insulate 1' concrete wall that meets 8' studded wall Truth Insulation 7 01-16-2012 08:14 PM
Hole in concrete block wall jjrbus Building & Construction 4 06-05-2010 01:32 PM
Question on hanging new door in concrete block wall dave11 Carpentry 7 11-12-2009 07:21 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 08:21 AM
