Framing Slanted Window In Shower - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-17-2016, 10:01 AM   #1
Rewards Points: 2
Framing slanted window in shower
Hello all,
I am redoing my master bath and I just finished putting the backer back on.
The exiting window is slanted there is 5/8" difference from the top to the bottom of the block window which is appox 24" square. I was thinking putting an addition piece of wood at the back of the wall at the top to make up for the difference and have the frame square. but if I do that both my side wall will be uneven by the same amount... which might be a problem for tiling 5/8 is quite a bit of difference... Any ideas beside removing the window.
Thanks a bunch
Z_Seb is offline   Reply With Quote
Old 11-18-2016, 02:43 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,260
Re: Framing slanted window in shower
Do you mean out of "plumb"?
If so, tile up to the window and cover the inconsistency with some trim tiles at the edge. Should help bury the elongated gap.
Basic help with window and door rough framing danf26 Building & Construction 3 08-20-2012 10:51 PM
Replacement Window Rough-In Framing Earnie Building & Construction 10 12-18-2011 10:07 AM
Deck - Framing around a bay window - house rim joist changes levels? jkwaldron Building & Construction 3 10-17-2011 08:24 PM
L framing for window shutters robismyname General DIY Discussions 3 02-03-2011 04:17 PM
How to properly seal window in tiled shower stall. Proby Kitchen & Bath Remodeling 0 07-21-2010 11:49 AM
