Framing For A Shower Stall With Glass - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-03-2017, 12:55 PM   #1
Framing for a shower stall with glass
Hi,
May have bitten off more than I can chew and would appreciate any help : )
I am looking to install a niche wall on the exterior (insulated) wall.
I am just curious of what else would be needed for framing in order to do so?
I will be having a glass door coming off the interior (non insulated wall). And glass panel on the other side
So if I'm correct. I will need a sill wrapping around the outside that will be 4.5" tall.
Besides that. A little lost what my next steps would be to have it ready for a drywaller to come in and board it up
Thanks for any advice!
Framing for a shower stall with glass-20170403_134424_1491241923224.jpg   Framing for a shower stall with glass-20170403_134406_1491241950263.jpg
Dennisthamennis is offline   Reply With Quote
Old 04-03-2017, 02:27 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,280
Re: Framing for a shower stall with glass
Double post,...
Bondo is online now   Reply With Quote
Old 04-29-2017, 03:24 PM   #3
Professional
Rewards Points: 188
Originally Posted by Dennisthamennis View Post
Hi,
Well you can't put the niche in an exterior wall but you could vb that exterior and then build a new interior wall. Alternatively, put the niche on an interior wall opposite your shower.
I think this one looks somewhat like where yours is going (minus glass) see the rest of link as well:
and here is one with the niche on the opposite of supply side:
https://i0.wp.com/104.236.153.149/wp...size=474%2C632
Make sure you have nailers in place for your glass.
A glass door is not always necessary and saves a load of money if you can just use a panel.
what is the area of your shower pan?
Str8AheadInc is offline   Reply With Quote
Frameless Glass Shower Install lynxpilot Kitchen & Bath Remodeling 12 10-23-2012 11:14 PM
Attaching a support to a shower glass partition john_bry Kitchen & Bath Remodeling 0 09-26-2012 09:31 PM
framing a shower stall n2learning Building & Construction 10 04-07-2011 07:34 AM
caulking shower stall questions, removal, grout sealing etc detyianni Plumbing 0 11-29-2010 09:00 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
